Home > Peripheral Devices >
  10pack of 25A Relays
Our Price: $39.99
Notes: Hobbyist Grade
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: COM-085
Description Extended Information
Fusion's official relay packs offer the easiest solution to controlling your car's systems. The relays feature easy connect spade adapters with a maximum allowed current of 25A. With the easy connect terminals with the standard Fusion header connector on the other end, this truly is a plug-n-play solution for the Fusion Brain.
Use this to computer control your electronic HVAC controls, interior and exterior lighting from neon accents to halogen headlights or foglights., single or multiple amps to finally eliminate start-up popping, and many other useful applications.
The Fusion Relays allow for lower guage wires to be ran from the Fusion Brain to the Fusion Relay Packs. By making the packs modular and not hard mounted to the Fusion Brain, it allows for more convenient positioning and shorter runs of high current wires.
Additionally, the relays are rated for up to 240vAC, making them acceptable for home automation use.
Includes 1m (3ft) cable for each relay.
Related Products...
Wireless WIFI Antenna with Pigtail
Our Price: $14.95
Add
ElmScan Compact 5 USB OBD-II by ScanTool
Our Price: $79.95
Add
USB Audio Selector 4 inputs 1 output
Our Price: $60.00
Add
ScanXL OBD-II Software by Palmer Performance
Sale Price: $79.95
Add
Fusion Brain Version 4.0
Our Price: $59.99
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Peripheral Devices
Peripheral Devices > Fusion Brain
Mp3Car Forum Made Products
3-pin Female-Bare Shielded Wire $1.99
AMP. INTEGRATOR PLUG - INTO CAR INTO AMP. HARNESS $0.99
Infrared Distance Sensor $24.99
MJS-SC-C1 USB Interface for Sirius Satalite Radio (Mjs-scc1) $61.99
FORD 88-94 AEROSTAR WITH EQ $0.99
2008 Double Din Bolt in kit Without Touchscreen $149.00
