Home > Monitors and Touchscreens > Monitor Accessories > Spare Monitor Parts >
  7" Touchscreen Replacement for 619 & 629 Lilliput (old version)
  7
Our Price: $50.00
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: MON-028
Description
Please note that these touchscreens are replacements for 619 and 629 Lilliput monitors purchased before April 18th 2008.
(If you purchased your monitor elsewhere, make sure that this is the correct version of the touchscreen that you need.)
This is a 7" Touchscreen - which has been removed from a brand new touchscreen and never used.
It is compatible with the Lilliput Monitors 619 and 629.  This is only the touchscreen, no controller board or LCD panel are included.
Measurements:  16.5 cm x 10.5 cm
Customers have also reported that this replacement screen will work in a EBY701-NP.
We carry touchscreen replacements for 619 and 629 Lilliput monitors purchased later than April 18th, 2008: MON-028-001.
Features
  • Touch Screen Panel
  • Size: 7"
  • Resistive 4-wire panel
  • Direct Replacement Lilliput panel
Related Products...
Extra 619 Lilliput Monitor Casing
Our Price: $20.00
Add
LCD controller ribbon cable 230 mm (15 inches)
Our Price: $2.99
Add
Extra Xenarc 700 series casing - Silver
Our Price: $20.00
Add
Our Price: $40.00
Add
7
Spare Lilliput Remote Control
Our Price: $3.99
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
2-pin Female-Male Shielded Extension Wire $1.99
6ft USB extension cable $5.00
CarNetix CNX-CA-XSC4 $24.99
ATC 10 gauge FUSE HOLDER W/Cover ATFH10C-10 $0.99
50A Current Sensor $19.99
