Home > Computer Hardware > Computer Cases >
  Ampie Car Computer Case
Pictured VIA MII12000 motherboard does not come with the case
Our Price: $69.95
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: ENC-005
Description Extended Information
The Ampie automotive enclosure is a small, rugged PC enclosure designed to work in harsh environments. The enclosure works with any type of mini-ITX motherboard (170x170mm) from fanless configurations such as VIA mini-ITX or Pentium or low power Pentium-M processors. The enclosure was designed to work with the M1-ATX automotive power supply unit. Works with one or two 2.5" drives, mounted on silicone rubber shock-mounts. It comes with wiring harness to easily connect to the M1-ATX and a quick release harness to connect to your vehicle that allows for easy removal.
    See more photos and information about this case in this thread on the forums http://www.mp3car.com/vbulletin/showthread.php?t=52755
    Features
    • Automotive mini-ITX enclosure
    • tough design, 5 mm aluminium extrusion
    • compatible with any mini-ITX board
    • works with M1-ATX automotive PSU - 210(W)x254(L)x56(H)mm
    • includes a fans for moisture/heat removal
    • includes wiring harness to connect to M1-ATX
    Average Customer Review: Based on 1 Reviews. Write a review.
    Related Products...
    Morex 5677 Mini-ITX Case Without PSU
    Our Price: $55.00
    Add
    Our Price: $85.00
    Add
    VoomPC-2 CarPC Enclosure
    Our Price: $79.95
    Add
    Vibration Damping Kit for OPUS ITX Case
    Our Price: $20.00
    Add
      2 of 2 people found the following review helpful:
    Room for Improvement December 28, 2007
    Reviewer: Patrick Knechtges from Lansing, MI United States
    I like this case but it is so heavy and the "fins" on the case really do not help keep it any cooler other than the looking cool factor.  The new case is much better with the needed improvements such as external USB ports and what not.  The case is nice though and fits an EPIA board an M1 or M2-ATX and a laptop HD perfectly but the puny fan lack cooling power. Hope this helps.
    Was this review helpful to you?
    Browse for more products in the same category as this item:
    Computer Hardware
