Home > Computer Hardware > Computer Cases >
  Ampie (VoomPC) Car Computer Case (Black)
Pictured VIA MII12000 motherboard does not come with the case
Our Price: $61.99
Notes: Discontinued
Stock Status:(Out of Stock)
Availability:: Ships in 1 to 2 Business Days
Product Code: ENC-005
Description Extended Information
The Ampie automotive enclosure is a small, rugged PC enclosure designed to work in harsh environments. The enclosure works with any type of mini-ITX motherboard (170x170mm) from fanless configurations such as VIA mini-ITX or Pentium or low power Pentium-M processors. The enclosure was designed to work with the M1-ATX automotive power supply unit. Works with one or two 2.5" drives, mounted on silicone rubber shock-mounts. It comes with wiring harness to easily connect to the M1-ATX and a quick release harness to connect to your vehicle that allows for easy removal.
    See more photos and information about this case in this thread on the forums http://www.mp3car.com/vbulletin/showthread.php?t=52755
    Features
      • Automotive mini-ITX enclosure
      • tough design, 5 mm aluminium extrusion
      • compatible with any mini-ITX board
      • works with M1-ATX automotive PSU - 210(W)x254(L)x56(H)mm
      • includes a fans for moisture/heat removal
      • includes wiring harness to connect to M1-ATX
    Browse for more products in the same category as this item:
    Computer Hardware
    AC/DC Power Brick 120 Volt AC to 12V DC 1.5A $7.49
    Lilliput 7" Touchscreen Replacement for the 669GL-70NP/C/T $13.95
    512MB DDR2 SODIMM PC2-667 RAM $19.99
    4-Port USB Hub USB-MH20-GRY $5.99
    4-Pin P4 - Molex Power Cable $3.99
