Home > Custom Car Computer Systems >
  Aopen MiniPC MP945-X Multi
  Aopen Pandora MiniPC MP945-X Multi
Some options as seen not available with the default system
Total texture satisfaction - Chic aluminum profile - Made entirely of aluminum alloy, AOpen MiniPC fully reflects the advent garde design. The teams of professional industrial designers at AOpen achieved the multipurpose goals of lowering the weight, strengthening the product, and accelerating heat dissipation while retaining the simple no-frills look. In addition, the special glossing treatment successfully gives the AOpen MiniPC an even more delicate and sleek touch. While rendering a chic look, the numerous small round dimples on the surface represent the countless functions provided by the little giant.
Stylish Design - Ultimate form/function combination - When creating a new generation of mini, simple and portable desktop PCs, designers have spent particulate effort on industrial design, structure, and functions. The AOpen MiniPC is not just a unique computer. It does not compromise functions for the small size, but strikes a balance between space and functions under the premise of simplicity. The AOpen MiniPC is not just a brand new portable desktop PC, but also an ultimate work of art developed via the digital information technology!
Slide-in optical disk drive - Saving the space needed by the traditional tray style drive, the unassuming dark, mystic and slim slot actually contains the space of unlimited power and vigor.
Integrated power button and indicator - The AOpen MiniPC both integrates and conceals the complicated functions into simplicity. The power button on the front panel also concurrently performs other functions as indicator of power source, hard disk, and optical disk.
Hidden air drawing openings - When other producers drill holes on their PCs to solve the heat problem, AOpen comes up with an innovative solution by employing the latest air flow design without compromising the beauty. Dozens of square openings concealed at the bottom enable the AOpen MiniPC to draw in adequate cold air and continue to work. This represents another balance of beauty and creativity.
Our Price: $270.99
Notes: Unavailable
Stock Status: In Stock
Product Code: BBN-011
Operating System:
Memory*:
Accessories:
Power Supply*:
Hard Drive BBN*:
Monitor:
WiFi:
Accessories
Microphone:
Satellite Radio:
XM Radio [Add $94.99]  (Subscription to XM Satellite Radio required.)
OBD-II:
OBD-II Support (ElmScan 5) [Add $129.95]
Description
Features
Product Name miniPC Duo miniPC Duo miniPC Duo
Model MP945-VXR MP945-VX MP945-X
Main Spec. CPU Intel Core 2 Duo / Core Duo CPU Intel Core 2 Duo / Core Duo CPU Intel Core 2 Duo / Core Duo CPU
FormFactor Proprietary Proprietary Proprietary
Chipset 945GM + ICH7M-DH 945GM + ICH7M-DH 945GM + ICH7M
Memory
Special Features ViiV Ready ViiV Ready
DVI / D-Sub / Y-Pb-Pr / S-Video DVI / D-Sub / Y-Pb-Pr / S-Video DVI / D-Sub / Y-Pb-Pr / S-Video
HD Audio, 5.1 CH HD Audio, 5.1 CH HD Audio, 5.1 CH
Gigabit LAN / 1394 / SATA II Gigabit LAN / 1394 / SATA II Gigabit LAN / 1394 / SATA II
SO-DIMM DDRII x 1 SO-DIMM DDRII x 1 SO-DIMM DDRII x 1
mini PCI Slot x 1 mini PCI Slot x 1 mini PCI Slot x 1
Super Multi / Combo (Option) Super Multi / Combo (Option) Super Multi / Combo (Option)
Built-In IR, Remote Control
TV Tuner (Option) TV Tuner (Option) TV Tuner (Option)
Wireless 802.11 b/g (Option) Wireless 802.11 b/g (Option) Wireless 802.11 b/g (Option)
SIZE WxHxD(inch) 6.49(W)x1.96(H)x6.49(D) 6.49(W)x1.96(H)x6.49(D) 6.49(W)x1.96(H)x6.49(D)
SIZE WxHxD(mm) 165(W)x50(H)x165(D) 165(W)x50(H)x165(D) 165(W)x50(H)x165(D)
Volume(liters) 1.36L 1.36L 1.36L
Weight(Kg/Pound) 1.45kg / 2.4 pound (N.W.) 1.45kg / 2.4 pound (N.W.) 1.45kg / 2.4 pound (N.W.)
Color Silver/Black Silver/Black Silver/Black
Chipset Intel 945GM+ICH7M-DH Intel 945GM+ICH7M-DH Intel 945GM+ICH7M
Power Solutions Two-phase voltage stabilization Two-phase voltage stabilization Two-phase voltage stabilization
Memory TYPE DDRII SO DIMM x 1 DDRII SO DIMM x 1 DDRII SO DIMM x 1
DDRII 533/667 533/667 533/667
Max memory size 2G 2G 2G
CPU TYPE Socket M 479 Socket M 479 Socket M 479
Support Intel Core 2 Duo (Merom)
Core Duo / Core Solo CPU (Yonah)
Intel Celeron M CPU
Intel Celeron M CPU
Intel Celeron M CPU
FSB 533/667 533/667 533/667
VGA CHIPSET Intel 945GM OnDie
Intel GFX 250 Mhz
Intel 945GM OnDie
Intel GFX 250 Mhz
Intel 945GM OnDie
Intel GFX 250 Mhz
DVI Connector DVI-I x1 DVI-I x1 DVI-I x1
VGA output Port 15 pins D-Sub via DVI-to-DVI/VGA Y adapte via DVI-to-DVI/VGA Y adapte via DVI-to-DVI/VGA Y adapte
HDMI Video interface none none none
TV Out Multi-TV out
(Composite + S-Video +Y-Pb-Pr)
Multi-TV out
Multi-TV out
CPU Thermal AOpen Thermal Module AOpen Thermal Module AOpen Thermal Module
Slot Internal mini PCI x 1 Internal mini PCI x 1 Internal mini PCI x 1
Audio TYPE HD Audio, 5.1CH HD Audio, 5.1CH HD Audio, 5.1CH
Line-In (Surround-Out L/R)* x1 x1 x1
Line-Out (Front-Out L/R)* x1 x1 x1
Mic-In (Central/Subwoofer out) * x1 x1 x1
S/PDIF Optical-Out x1 (via Adapter) x1 (via Adapter) x1 (via Adapter)
LAN(RJ-45) Intel 10/100/1000 Intel 10/100/1000 Intel 10/100/1000
ATA Connector for Slim Optical for Slim Optical for Slim Optical
S-ATA Connector for 2.5" HDD for 2.5" HDD for 2.5" HDD
USB 2.0 2(Rear) 2(Rear) 2(Rear)
IEEE 1394 1(Rear, 6pins) 1(Rear, 6pins) 1(Rear, 6pins)
Chassis ODD bay Slot-in Slim ODD x1 Slot-in Slim ODD x1 Slot-in Slim ODD x1
Front Cage hidden Mic x1 hidden Mic x1 hidden Mic x1
2.5" HDD bay 2.5" SATA HDD x 1 2.5" SATA HDD x 1 2.5" SATA HDD x 1
Power Supply 65W (19V, 3.5A) AC Adapter 65W (19V, 3.5A) AC Adapter 65W (19V, 3.5A) AC Adapter
Input Volotage AC 100~240V AC 100~240V AC 100~240V
Operating Temperature 10 ~ 35 ℃
(50 ~ 95°F)
10 ~ 35 ℃
(50 ~ 95°F)
10 ~ 35 ℃
(50 ~ 95°F)
Storage Temperature -10 ~ 48 ℃ -10 ~ 48 ℃ -10 ~ 48 ℃
Operating Humidity 5 ~ 95%RH 5 ~ 95%RH 5 ~ 95%RH
Supported OS Windows XP/MCE Windows XP/MCE Windows XP/MCE
Slim Optical Disk Device
Remote control Yes none none
Note none none none
AOpen Reserves the right to revice all the specifications and information contained in this document, which are subject to change without notice.
1 Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount.
2 Switch by Utility Software
3 The IR / Remote Control of AOpen accessory is not supported under Windows XP and Windows XP MCE.
Complete Functions - Totally satisfying all-round functions
Despite its mini size and unadorned appearance, the AOpen MiniPC possesses complete functions to give you a most unraveled experience.
Wireless Internet surfing- The Internet access with built-in IEEE 802.11 b/g frees you from the restrictions of "wires and cables." You can now roam freely on the Internet anytime anywhere. The AOpen MiniPC is not just compact but can also give you total freedom!
High-speed network LAN - Even endowed with wireless functions, you may still need higher speed when transmitting files and browsing resources through the local area networks (LAN), or downloading massive image and audio materials at fixed places like the office or at home. The high-speed Gigabit 1000Mb network connecting port of the AOpen MiniPC can not just meet your needs but can also be compatible with the traditional 10/100Mb networks.
Digital video interface (DVI) - Through its high-resolution digital video output port, the AOpen MiniPC can generate high-resolution and high-quality video data. When using a new generation LCD monitor, you will personally experience the unprecedented display quality for the transmitted digital signals. Meanwhile, the digital video output port can also support any model of LCD or CRT via the attached adapter.
TV signal output- Another thoughtful design is the S-Video connector provided by the AOpen MiniPC that allows you to flexibly make use of your home TV set or monitor. This further enhances the portability of the AOpen MiniPC because you can use AOpen MiniPC at more places without having to consider if a PC monitor is available. You may continue to enjoy your digital life with the AOpen MiniPC as long as you own a TV set.
HDTV-For consumers who have high-definition TV (HDTV) set, the AOpen MiniPC provides even more stunning viewing delights through the Y/Pb/Pr connector. The more precise colors and delicate details shown on HDTV sets are beyond comparison with traditional CRTs. This enables you to handle computer work on your TV set. Now you can hook up the AOpen MiniPC to your TV in the living room to easily process documents, business, and even edit pictures and images. These functions are not limited only to surfing Web pages, listening music or viewing photos and movies.
Dual screen display-AOpen MiniPC can simultaneously support two monitors, enabling you to surf the Web pages and watch TV programs at the same time, or enjoy entertainment while you are working.
High capacity DVD±RW / CD-RW burner- Being even smaller than an external CD/DVD burner, the AOpen MiniPC contains a slim built-in burner. You only need minimum space to easily carry around this petite, yet full-fledged PC. In addition, the high-capacity hard disk inside the AOpen MiniPC lets you record, duplicate, and store much more data or video data.
High-speed USB 2.0 port- The AOpen MiniPC provides two universal serial bus input/output ports at the back to expand the connectivity with peripheral equipment. You can connect to USB flash drive, external CD/DVD burner, printer, scanner, etc. In spite of its mini size, the AOpen MiniPC gives you unlimited expansion possibilities! Furthermore, the USB 2.0 protocol of AOpen MiniPC also allows the support for the older USB 1.1 specifications.
IEEE1394 serial bus port -The AOpen MiniPC provides the high-speed serial bus port to connect to the typical peripherals like digital video recorder, high-speed hard disk drives, etc. With the above high-speed USB 2.0 port, AOpen MiniPC supports the great majority of external peripherals on the market.
Related Products...
Telematics, Fleet & Public Service Bundle - Mobile
Our Price: $899.00
Add
Telematics, Fleet & Public Service Bundle - Mobile Car Computer System
Guru Double Din Car Computer
Our Price: $2,999.99
Add
Power Bundle - Mobile Car Computer System
Our Price: $594.95 Please allow up to 3 business days for processing.
Add
Budget Bundle - Mobile Car Computer System
Sale Price: $415.00
Add
Fanless Micro Intel Vehicle Computer
Our Price: $287.00
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
