Home > Computer Hardware > Cables and Adapters > Cable Kits >
  Aopen MiniPC plug-and play Power Button Cable Kit for P1900
Our Price: $14.99
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: CBL-003
Description
This kit is designed to provide a plug-and-play (ie no soldering) connection to the AOpen power button which can be extended outside of the AOpen chassis and connected to the ACPI output of the P1900. This cable will simplify, and make more reliable the AOpen/P1900 installation. The cable kit contains two pieces. One piece is inserted between the front panel switch pcb cable and the motherboard. The second piece provides a removable cable section for connecting to the P1900 ACPI output. This allows you to easily remove the AOpen from the car so that you can take it indoors for software updates.
This cable is about 12" long.  It can be extended for people who would like more separation between their Aopen and their Carnetix.
Related Products...
Cable Ties 8-1/2" Black 100 Pcs.
Our Price: $4.99
Add
Cable Ties 8-1/2
Sumicomm/Xenarc/Commell/IWill Case Power Cable
Our Price: $6.95
Add
DVI Analog Male to VGA Female Adaptor
Our Price: $10.99
Add
ATC 10 gauge FUSE HOLDER W/Cover
Our Price: $0.99
Add
uSDC Cable Kit
Our Price: $9.99
Add
uSDC Cable Kit
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
CarNetix Products (CNX)
AC/DC Power Brick 120 Volt AC to 12V DC 5Amps $29.99
Lilliput 16.4 Foot 10-pin din cables for Lilliput 629GL-70NP/C/T and 889GL-80NP/C/T $40.00
Fusion Brain Version 4.0 $59.99
ATM 16 Gauge Fuse Holder w/Cover ATFH16MC-10 $0.99
Lilliput 629GL-70NP 7" VGA Touchscreen $239.99
30 Minutes of Consultation ($330 per hour, purchased in 30 minute increments) $165.00
Install Bay 80 Amp Manual Reset Red Button Breaker CB80MR $9.99
1/2 " Self Wrapping Split Braided Sleeving- Fire retardant - by the foot, techflex $0.99
