Home > Computer Hardware > Cables and Adapters > Cable Kits >
  Aopen Power Pac
  Aopen Power Cable Kit
Our Price: $24.95
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: CBL-024
Description
Worried about cutting up your Aopen Pandora Mini-PC power brick to complete your car-pc install? No need. The Aopen Power Cable kit is the first plug-and-play power kit designed to work with the Aopen Pandora Mini-PCs and Carnetix DC-DC regulators (P1900 and P2140).
The kit comes with the power wiring kit as well as the power-button kit. The power wiring kit plugs into a Carnetix P1900 or P2140 regulator and it plugs directly to the power connection on the back of the Pandora Mini-PC giving you a quick way to install the PC in your car. The Power-button kit on the other hand allows you to retain the functionality of the power button on the Aopen case while allowing the Carnetix DC-DC regulator turn the PC on/off with the ignition.
The Aopen Power Cable kit gives you the portability that Mac Mini users have enjoyed for a while. With this kit you won't need to cut your stock power brick, therefore you can port your PC between your house and your car without any wiring hassles.
Related Products...
Cable Ties 8-1/2" Black 100 Pcs.
Our Price: $4.99
Add
Cable Ties 8-1/2
Extra Monitor Power Cable
Our Price: $4.99
Add
DVI Analog Male to VGA Female Adaptor
Our Price: $10.99
Add
ATC 10 gauge FUSE HOLDER W/Cover
Our Price: $0.99
Add
uSDC Cable Kit
Our Price: $9.99
Add
uSDC Cable Kit
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
CarNetix Products (CNX)
Computer Hardware
Morex 5677 Mini-ITX Case Without PSU $55.00
Xenarc 702TSV VGA Touchscreen Monitor, 1000nit $484.99
Morex 5677 Mini-ITX Case w/ 2.5" HDD Mount with PSU $85.00
Xenarc 700TSV 7" TFT LCD Touchscreen Monitor $359.95
MP3CAR USB GAMEPLATE WITH 110 VOLT A/C PLUG AND RCA'S! $32.99
Stage 2 - Above the Basics $367.99 Please allow up to 3 business days for processing.
Klear Screen High Performance Cleaning Kit $2.99
