Mobile Systems Integration Specialists
http://www.mp3car.com
View Cart
I
My Account
I
Login
Home
About Us
Help
Contact Us
Our Products
New Products
Open Source Hardware
Vehicle Specific Parts
Mp3Car Forum Made Products
Embedded & Industrial Computers
Custom Car Computer Systems
Monitors and Touchscreens
Computer Hardware
iPad Vehicle Mounts
CarNetix Products (CNX)
Navigation and Software
Engine Diagnostics and OBD
Audio, Radio, and Video
Peripheral Devices
Power
Fusion Brain & Accessories
Mp3Car Swag
Mp3Car Bargain Basement
Information
Mimics
Mp3Car Store Policies & FAQ
Review Your Experience Here
Premium Services & Support
Contact/About Us
Car Computing FAQ
Mp3Car Forums
Mp3Car Homepage
Home
Power
Point Of Load
DCL11 Automotive Point-Of-Load DC-DC 15W Power Supply
Our Price:
$42.99
Stock Status:In Stock
Product Code:
PWR-022
Accessories:
None
Metal Tray/Heatsink for POL PSU [Add $7.00]
Description
Technical Specs
Extended Information
OPUS Solutions Point Of Load DC-DC smart power supply, is designed specifically for powering peripheral devices used in an automotive environment. The Power-ON lead is monitored to start the device when the power is turned on. The input power is protected against transients and load dumps. It also uses technologies to maximize efficiency, performance and reliability. The Point Of Load DC-DC power supply is a step-down regulator, the input voltage must always be higher than the set output voltage.
Input:
Normal input voltage: 6.5V to 30V (note: input voltage must be greater than output voltage by approximately 1.5V, for example the 12v output won't work with 12v input, see one of our other power supplies for that application)
Input protection LC Pi Filter
Input Fuse: 1.8A PTC
Quiescent current drain: <2mA
Input power mating connector: Plug: Molex:P/N:39-01-4030
Crimps: Molex:P/N:30490-2012
Output:
Output voltage: 5V
3A max, 3.5A Peak or 15W max
Voltage selection is set by a 2mm shaunt jumper
Output power connectors: 2pin screw terminal (5mm pitch)
General:
Power efficiency: >90%
Operating temperature range: -25C to 70C
MTBF: 300,000hrs min.
Cooling: Forced air or thermal coupling to heat sink for loads over 10W
External dimensions of PCB module: 70mm x 27.5mm x 12.7mm
2.75" x 1.09" x 0.5"
Part Number DCL11
Additional product information:
DCL11 Manual
Please note:
Mp3Car will not provide tech support in regards to use and set-up of this product. Customers are expected to use the
Mp3Car forums
for assistance in these areas. A good place to start is the
Mp3Car Power Supply sub-forum
. Registration on the forums is easy and free.
Features
1A - 3A output (15W max)
Wide input voltage range
Load dump protected
On/Off power switch input
High Efficiency DC-DC Power Supply (extended battery life)
Simple to install
Related Products...
Carnetix CNX-P5V 15 Watt +5V Regulator
Our Price:
$24.95
Add
Browse for more products in the same category as this item:
Power
Point Of Load
Power
Automotive/Marine Grade USB Cigarette Port Replacement
$24.99
Andrea Electronics Superbeam Array Microphone Bundle SUMA
$39.95
Andrea Electronics Microphone DA-350 linear multi-element array
$329.99
AC/DC Power Brick 120 Volt AC to 12V DC 1.5A
$7.49
