Home > Peripheral Devices > GPS Receivers >
  BU-353 Weather-proof GPS Receiver
Alternative Views:
Our Price: $27.99
Stock Status:In Stock
Product Code: GPS-002
Description Technical Specs Extended Information
The USGlobalSat BU-353 is a completely self-contained and waterproof GPS receiver that easily connects to your mini-ITX computer through a USB connector. With non-slip on the base and its compact deasign, the BU-353 can be utilized in a variety of applications that may require magnetic mounting with a waterproof configuration. It incorporates the latest SiRF Star III GPS chipset and an active patch antenna so you receive the highest degree of GPS accuracy.
Includes a driver to convert the USB port into a virtual COM port so it can work with most NMEA compliant mapping software on the market today.
Since the BU-353 includes both the antenna AND receiver in one unit, all you need is GPS software.  You can either purchase a stand-alone GPS program, or you can purchase a software front end that includes GPS data.
Features
  • 1. SiRF Star III High Performance GPS chipset - WAAS
    2. High sensitivity (Tracking Sensitivity: -159 dBm)
    3. Extremely fast TTFF (Time To First Fix) at low signal level
    4. Support NMEA 0183 data protocol
    5. Built-in SuperCap to reserve system data for rapid satellite acquisition
    6. Built-in patch antenna.
    7. Super-cohesive magnetic for mounting on the car
    8. USB interface connection port.
    9. Waterproof and non-slip on the bottom.
    10. LED indicator for GPS fix or not fix.
          LED OFF: Receiver switch off
          LED ON: No fix, signal searching
          LED Flashing: Position fixed
Browse for more products in the same category as this item:
Peripheral Devices
Peripheral Devices > USB Peripherals
DCL11 Automotive Point-Of-Load DC-DC 15W Power Supply $42.99
Automotive/Marine Grade USB Cigarette Port Replacement $24.99
Andrea Electronics Superbeam Array Microphone Bundle SUMA $39.95
Andrea Electronics Microphone DA-350 linear multi-element array $329.99
