Home > Computer Hardware > Computer Cases >
  Black Double Din Nano-ITX Carputer Enclosure
Our Price: $54.95 No Longer Available
Stock Status:(Out of Stock)
Product Code: ENC-032-B
Description Technical Specs Extended Information
  • Standard double din mounting size
  • Black Box
  • Compact user friendly design for easy access and maintenance
  • Fits standard Nano-ITX form factor boards
  • Pico-ITX & SBC Boards installable with standoffs
  • Fully ventilated with 40mm cooling fan
  • Internal amplifier can be installed inside (optional)
  •  LCD frame can hold 7" Lilliput® lcd screens
  • Some double din dash kits may require 3-4 mm trimming to fit the LCD frame
Black Box-N brings a robust solution for the Carputer enthusiasts willing to install their double din in dash infotainment system. Built of high resistance ABS plastic, this fully ventilated rugged enclosure provides secure support to the small from factor boards as well as the 7" LCD touch screens from Lilliput Electronics® (LED version).
Fully customizable: The ABS plastic material makes it easy to add custom devices by drilling holes and adding adhesive standoffs on the desired positions. Its removable cut out window exposes fixed board ports
Recommended hardware
Motherboard
  • Via Epia NX15000G
  • Via Epia N1200EG
  • Portwell Nano-8044 series board
  • Contron SBC (Single Board Computer)
  • Via Pico-ITX boards
   Power Supply
   Memory
  • 1GB DDR2 533 SODIMM
LCD Screen
Storage
The Benefits of ABS
ABS possesses outstanding impact strength and high mechanical strength, which makes it so suitable for tough consumer products.  Additionally, ABS has good dimensional stability and electrical insulating properties. ABS plastic is versatile, lightweight, flexible, moisture and corrosion resistant, durable, strong, heat resistant and relatively inexpensive. It is  also fully recyclable.
Browse for more products in the same category as this item:
Computer Hardware
BU-353 Weather-proof GPS Receiver $27.99
DCL11 Automotive Point-Of-Load DC-DC 15W Power Supply $42.99
Automotive/Marine Grade USB Cigarette Port Replacement $24.99
Andrea Electronics Superbeam Array Microphone Bundle SUMA $39.95
Andrea Electronics Microphone DA-350 linear multi-element array $329.99
