Home > Our Products > Computer Hardware > Computer Cases >
  Black Double Din ABS Frame For Lilliput 629-GL or EYB-701
Black Double Din Nano-ITX Carputer Enclosure
Our Price: $27.99
Sale Price: $19.99
You save $8.00!
Stock Status:(Out of Stock)
Availability:: Ships in 1 Business Day
Product Code: ENC-033-B
Description Extended Information
This ABS plastic lcd frames makes the LCD installation process easy and secure. Now you can install and remove your lcd component as many times as needed without compromising your screen's integrity. It is intended to be installed behind the OEM radio bezel or any double din dash kit. (Some dash kits may require slight modification to fit the frame).  Easily bolts into many of the aftermarket dash panel kits from Metra and Scosche.
ABS is a strong and rigid plastic, used on many automotive applications such as dash panels, dash boards, radio bezels, handles, etc. Its color and texture helps preserve your car's original look.
Dimensions:
  • Width:  177mm
  • Height:  107mm
  • Depth:  71mm
Material:  ABS Plastic
Package Contents:
  • LCD frame
  • Bracket
  • Mounting Tabs
  • 4 Mounting Screws
  • 6" Flat Ribbon Cable to Extend the IR Component.
  • Printed Installation Instructions
Browse for more products in the same category as this item:
