This kit is compatible with the LED version of the Lilliput 629. This kit could be used with the LED version of the 619, however it is not advised.
This kits does not require modifications to dashboard and can simply be bolted into place. To install, simply bolt it into place. This housing is compatible with the following models:
Impreza WRX/STI 2002-2007 Forester 2001-2007 Legacy 2005-2007 Outback 2005-2007 Baja 2005-2007
Requires Metra Electronics Kit 99-5087 available at Circuit City
According to metraonline.com, kit will work for the following vehicles:
F150 2004-2007
Mustang 2004-2007
Lincoln Mark LT 2004-2007
Mercury
Montegro/Mountaineer 2005-2007
We have had customers adapt this kit to other vehicles with double DIN openings. Be advised: We are not guaranteeing an exact fit and this may require some modifications on your behalf to make it work. If you think it might fit in your 2DIN opening the Housing Dimensions are: W(7") x H(4.3") x D(7.8") also Here. |
