Home > Power > Startup/Shutdown Controllers >
  Serial port for DSATX (Brainstem TTL to RS232 module)
Our Price: $16.99
Stock Status:In Stock
Product Code: COM-021
Description
Mp3Car Description: This module is designed to provide a serial port control for the DSATX. It connects directly on the DSATX power supply and allows you to do things like tweak settings and monitor performance as well as update the firmware.
Manufacture’s Description: The new BrainStem connector. This connector plugs directly into a module and offers conversion from TTL to RS-232 levels. Included are indicator LED's for host serial power and stem logic power.
The interface connector has a female four pin connector on one end. On the other end is a female DB9 connector, which can plug into your Windows serial cable, or be used with the USB 1.1 to Serial Adapter which can be used with your Mac or Windows USB hub. The CTS and RTS lines are also connected and exposed although not used by the 4-pin BrainStem connector. These can be separately wired for other uses in your application.
Browse for more products in the same category as this item:
Power > Intelligent Automotive ATX Power Supplies
Power
Black Momentary Pushbutton Switch 12.5mm $4.99
BU-353 Weather-proof GPS Receiver $27.99
DCL11 Automotive Point-Of-Load DC-DC 15W Power Supply $42.99
Automotive/Marine Grade USB Cigarette Port Replacement $24.99
Andrea Electronics Superbeam Array Microphone Bundle SUMA $39.95
