Search
Main Menu
Join our mailing list!
(Your shopping cart is empty)
Home
Power Supplies
Shutdown Controllers
CarPC Pro v2.5d - The Advanced ATX Power Controller
Our Price:
$95.00
Stock Status:
(Out of Stock)
Product Code: PWR-014
Description
Extended Information
Power Controllers are electronics that connect to your PC to automatically sequence them, and other electronics, on and off properly and safely with the car. These units will also control the power on your inverter or DC-DC Power Supply, amplifiers, and Screens.
These Power Controllers are designed for the CarPC users who want a no-hassle, reliable, comprehensive installation.
With features like Low Voltage Monitor to prevent your battery from being dead when you come out to your car, support for Shutdown to Standby, Power Pulse Mode for those users who like their PC to be running before they enter the car, and Ultimate Flexibility, these are the most comprehensive and flexible SDCs on the market.
Features
Automatic Safe PC Startup/Shutdown
- Prevents data loss and corruption by properly starting and shutting down your CarPC.
Dual Temperature Sensors
- Prevents Hard Drive and other hardware failures by monitoring temperatures of your hard drive and the temperature inside your CarPC case. The CarPC Pro prevents PC startup during extreme temperatures as well as shutting down the PC when and if temperatures reach extremes. Jumper settings allow the user to adjust or disable the temperature sensors.
Temperature Ignore
- Using this feature, you can have the Power Controller ignore the temperatures so that you may startup the PC during emergencies such as being lost and needing your GPS, or during a demonstration of your setup when it's extremely hot.
- Every timer and many options related to the control of the PC, Inverter, Amps, etc. are user-adjustable. They are digitally selected and stored, will not drift like pots (which other SDCs use), are saved indefinatelly even during power loss. See the
Configuration Manual
for information relating to these settings.
Shutdown to Standby Support
- Using this Option, your PC can shutdown to standby. This is useful because Shutdown/Startup to/from Standby is much faster than when using Hibernate.
Power-Protect
™ - Monitors vehicle voltage levels and will prevent the PC from turning on or will shutdown the PC when the car battery is too low. Jumper settings allow the user to adjust or disable the voltage monitor.
Battery-Safe
™ - Forces PC to shutdown if it hangs with the car off. Prevents you returning to a car with a dead battery due to your CarPC after a long day of work or play.
Amplifier Turn-On Circuit
- Turns on and off external amplifiers
Screen Turn-On Circuit
- Turns on and off all your screens
Works with Any PC
- PC and Operating System must be
ACPI Compliant
and properly detected as such by whatever Operating System is being used.
On-Glitch Saver
™ - Makes sure that the key is on before turning the PC on. This also allows you to quickly do anything that requires the key to be on such as rolling up a window.
Stay-On
™ - Allows you to turn off your car engine and not effect the CarPC. This comes in handy when filling up at a gas station where you want to shut off the car but not the PC.
Anti-Thump
™ - Specialized sequencing of your amplifiers (if any) on and off in a specific order to prevent harsh Thump that results from the PC turning on and off.
PC Compatibility
- Works with ATX, Mini-ITX, and µ-ITX motherboards and Power Supplies.
OS Compatibility
- Works with ACPI Compliant Operating System
PC-Monitor
- Our Power controllers will NEVER get confused about whether the pc is on or off.
Trip-Off
- Can turn off the PC while the car is running without turning off the power controller.
Adjustable Low Voltage Levels
Adjustable
Temperature
Range
Quick Connect Cables
Modify Startup Timers
Valet/Alarm Mode
- Keep the PC from turning on when others will drive your car or when your alarm has gone off.
Control Other Items
- Control Power to up to 20 items. See the
Accessory Manual
for details.
Remain-On Mode
- Allows the PC to stay on with the car off. The PC will then turn off if the temperatures become extreme or voltage levels drop too low. See the
Accessory Manual
for details.
Instant-Off Mode
- Allows you to instantly switch off the PC and other devices using a switch. See the
Accessory Manual
for details.
Serial
Port
Shutdown
- Shutdown the PC via serial port. Useful for those laptop users. You must click the "Add Serial Shutdown" button below to receive the additional hardware and software.
Professionally Manufactured
Related Products...
Micro Shutdown Controller
Our Price:
$41.99
Add
Share your knowledge of this product with other customers...
Be the first to write a review.
Browse for more products in the same category as this item:
Power Supplies
Power Supplies
Startup/Shutdown Controllers
Power Supplies
MP3Car
3 Churchberry Ct.
Reisterstown, MD 21136
About Us
Privacy Policy
Send Us Feedback
Company Info
Product Index
Category Index
Help
Terms of Use
Copyright © 1999 - 2008 MP3Car.com Inc.. All Rights Reserved.
Sell Online
with Volusion.
