Description 3-Liter Mini-ITX Chassis M/B Form Factor Mini-ITX (6.7" x 6.7")
Security Intrusion Switch Kensington lock Chassis Dimension | D x W x H (mm) | 230 x 75 x 220 (mm) | | D x W x H (inch) | 9.1" x 3" x 8.6" |
Power Supply | Form Factor | External adapter | | Watt | 60 W |
Drive Bay | Hot-Swap 3.5" | - | | Hot-Swap 2.5" | - | | External 5.25" | - | | External 3.5" | - | | External 2.5" | - | | Internal 3.5" | - | | Internal 2.5" | 1 or 2 | | Slim ODD | 0 or 1 | | Slim FDD | - | | Card Reader | 1(SD/Mini-SD/MMC/MS)(Optional) |
| Generality | Metal Material | SECC | | Metal Thickness | 0.6 mm | | Metal Material Type | ABS-HB |
System Cooling | Front | Top :1 x 60 mm (Optional) | | Rear | 1 x 40 mm (Optional)(Atom version : No system fan) |
Front Panel | Front Control | Power On/Off USB 2.0 Ports(x2) Audio(x2) IEEE1394 (Optional) | | Indicator | Power LED(x1) HDD Activity LED(x1) |
Shipping Information* Net Weight (Chassis Only) | 1.38 kg | | Gross Weight (w/Packing) | 2.18 kg | | Cubit Feet | 0.8 | | Container Information | | 20' | 1328 (Single Packing) 3360 (Bulk Packing + Pallet ) | | 40' | 2728 (Single Packing) 7280 (Bulk Packing + Pallet ) |
