Home > Computer Hardware > Motherboards > Intel >
  D945GSEJT Intel Mini-ITX board -Fanless , 2gb Max, 1.6Ghz Atom, sata, 12v
Alternative Views:
Our Price: $109.99
Stock Status:In Stock
Product Code: MTB-061
Memory*:
WiFi:
   Includes antenna & pigtail connector.
Description Extended Information
The Intel® Desktop Board D945GSEJT is designed for users demanding affordable yet stylish Internet-centric computing solutions. This breakthrough platform addresses emerging slim nettops, affordable all-in-one PCs, thin/enriched-client PCs, and other usage models with its versatile, low-power, thin form factor design.
Links
Checkout a video of the board (link). - SSD Not Incuded
View the D945GSEJT Intel Product Breif (link)
View D945GSEJT Intel Product Guide (link)
D945GSEJT Main Specifications
Product Description Intel Desktop Board D945GSEJT With integrated Intel Atom processor N270 - motherboard - mini ITX / micro ATX - i945GSE
Packaged Quantity 10 (specifications are for single item)
Product Type Motherboard
Form Factor Mini ITX / micro ATX
Dimensions (WxDxH) 6.7 in x 6.7 in
Chipset Type Intel 945GSE Express / Intel ICH7-M
Max Bus Speed 533 MHz
Processor 1 ( 1 ) x Intel Atom N270 / 1.6 GHz
Cache Memory L2 - 512 KB ;
RAM 0 MB (installed) / 2 GB (max) - SO DIMM 200-pin
Supported RAM Technology DDR2 SDRAM
Storage Controller ATA-100, Serial ATA-300
USB Ports Configuration 7 x USB
Storage Ports Configuration 1 x ATA, 2 x SATA
Graphics Controller Intel GMA 950 - Dynamic Video Memory Technology 3.0
Audio Output 2ch (single) / 2+2ch (multi) HD audio (analog); digital audio via SPDIF
Front panel mic/headphone header
Networking Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet
Vista Certification Works with Windows Vista
General
Width 6.7 in
Depth 6.7 in
BIOS Type Intel
Processor
Type Intel Atom
Installed Qty (Max Supported) 1 ( 1 )
Clock Speed N270 / 1.6 GHz
Data Bus Speed 533 MHz
Cache L2 - 512 KB
Memory
RAM Installed ( Max ) 0 MB / 2 GB (max) - SO DIMM 200-pin
Supported RAM Speed PC2-4300, PC2-6400, PC2-5300
Video
Video Memory Dynamic Video Memory Technology 3.0
Audio
Audio Output Sound card
Audio Codec Realtek ALC662
Compliant Standards High Definition Audio
Telecom / Networking
Features
BIOS Features ACPI support, rapid BIOS boot, WfM 2.0 support
Hardware Monitoring CPU core temperature, system voltage
Sleep / Wake Up Keyboard wake up, mouse wake up, wake on USB port
Hardware Features Chassis intrusion detection
Expansion / Connectivity
Expansion Slot(s) 1 memory - SO DIMM 200-pin
1 PCI
1 PCI Express Mini Card
Storage Interfaces Serial ATA-300 - connector(s): 2 x 7pin Serial ATA - 2 device(s)
ATA-100 - connector(s): 1 x 44pin IDC - 2 device(s)
Interfaces 3 x Hi-Speed USB - 4 pin USB Type A
1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x display / video - DVI-Digital
1 x audio - line-out/line-in
Additional Connectors (Optional) 4 x Hi-Speed USB
Miscellaneous
Works with Windows Vista Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Compliant Standards VCCI, EN 60950, EN55022, EN55024, CISPR 22, ICES-003 Class B, RoHS, UL 60950-1, IEC 60950-1, FCC CFR47 Part 15 B
Browse for more products in the same category as this item:
Computer Hardware
Cigarette Lighter Power Adapter for Monitors $5.99
Centrafuse Auto 4.0 Navigation Edition North America $124.99
Carnetix CNX-P5V 15 Watt +5V Regulator $24.95
CarNetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator $99.95
Mac Mini Power Button Cable Kit For Pre March 2009 Models $10.00
