Home > Power > Intelligent Automotive ATX Power Supplies >
  OPUS 150 watt DC-DC Power Supply for Shuttle PC's DCX2.1215.XPC
Our Price: $189.99
Sale Price: $149.99
You save $40.00!
Notes: Unavailable
Stock Status:(Out of Stock)
Availability:: Ships in 24 to 48 Hours
Product Code: PWR-004
Description
This model has a special bracket designed to replace the factory power supply for Shuttle PC's.
The OPUS Solutions 150 watt power supply is the premier power supply for the automotive environment. It is carefully designed from the ground up with the harsh automotive environment in mind. The DC-DC power supply is designed to provide a steady 150 watt output over a variety (8-19V) of input voltages. This gives it the ability to withstand the voltage drop during an engine crank without rebooting the PC. The power supply works with ATX motherboards and safely monitors and controls the motherboard with smooth startup and shutdown procedures.
Connectors: 1-ATX, 3 HDD, 1FDD, P4 Header
For more information view the Owner’s Manual
Browse for more products in the same category as this item:
Power
D945GSEJT Intel Mini-ITX board -Fanless , 2gb Max, 1.6Ghz Atom, sata, 12v $109.99
Cigarette Lighter Power Adapter for Monitors $5.99
Centrafuse Auto 4.0 Navigation Edition North America $124.99
Carnetix CNX-P5V 15 Watt +5V Regulator $24.95
CarNetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator $99.95
