Home > Monitors >
  Direct Fit Double Din LCD Touch Screen for 2004-2008 Ford F150
Our Price: $299.99
Stock Status:In Stock
Product Code: DSH-150
Monitor Options:
Description
lease allow up to 5 business days for assembly.
Our double din kits pair the finest quality aftermarket dash panel kits from Scosche, Metra, or others with our own double din frame and the Lilliput EBY701 monitor (other monitors are optional) for a truly remarkable and integrated solution for your vehicle.  Fitment in your car is a breeze.  Pair one of these with one of our Custom Car Computers and you're ready to go.  180 day limited warranty on the LCD panel.  The IR sensor has been relocated to the front of the frame so you may still use your remote.  The auto backup camera wire is exposed with all monitor options EXCEPT the Lilliput 669GL-70NP/C/T.  This allows the monitor to automatically switch to a second video input when a +12V signal is applied to the monitor (i.e. when you shift into reverse).
  • High Resolution Display up to 1024 x 768
  • New Model 2010 is 400:1 contrast ratio and LED back light
  • VGA input
  • Touch Screen Function with USB interface
  • 2 Video inputs
  • Computer display/S-video/DVD/VCD/Navigation system/ Rear view camera
  • Compatible RCA & VGA Cables included
  • Native ratio: 16:9 wide TFT screen
  • Color configuration: RGB stripe
  • Video system: PAL/NTSC
  • Fully functional IR remote control
  • Full function OSD control (Multi-language)
  • Video input signal: 1.0Vp-p, composite video
  • Power input: DC 12V
  • Power consumption: 9W
  • Brightness: 400
  • Responsive Time: 30Ms
  • Remote control
  • 6 feet VGA / USB extension
  • Touch pen
  • 12 V AC/DC power adapter
  • 12V DC power input with filter
  • SKS (RCA Inputs) cable
  • Drivers CD
  • Operations manual
  • Metra or Scosche installation manual
Browse for more products in the same category as this item:
Monitors
Monitors and Touchscreens > Vehicle Specific Parts
Monitors and Touchscreens > Lilliput
Monitors and Touchscreens > 7" Touchscreens
Monitors and Touchscreens > In-Dash Touchscreens
Monitors and Touchscreens > Vehicle Specific Parts > Ford
Monitors and Touchscreens > Vehicle Specific Parts > Ford > F150
