Home > Vehicle Specific Parts >
  Double Din Bolt in Kit with the 7" 629 Lilliput Touchscreen
  Double Din Bolt in kit
Actual kit is brushed aluminum instead of the coated black aluminum pictured.
Our Price: $499.00
Stock Status: (Out of Stock)
Product Code: DSH-016-0001
Sunlight Readable Monitor:
Description Technical Specs
Mp3Car offers installation service for the bolt-in kit, using the 629 Lilliput monitor.
If you are not too keen on voiding your warranty, the Mp3Car team will do it for you and warrant the product.
(Please see the the Mp3Car warranty policy for details.)
This kit and touchscreen does not require modifications to dashboard and can simply be bolted into place. To install, simply bolt it into place.
This housing is compatible with the following models:
Impreza WRX/STI     2002-2007
Forester                   2001-2007
Legacy                     2005-2007
Outback                   2005-2007
Baja                         2005-2007
Requires Metra Electronics Kit 99-5087 available at Circuit City
According to metraonline.com, kit will work for the following vehicles:
F150 2004-2007
Mustang 2004-2007
Lincoln Mark LT 2004-2007
Mercury Montegro/Mountaineer 2005-2007
We have had customers adapt this kit to other vehicles with double DIN openings. Be advised: We are not guaranteeing an exact fit and this may require some modifications on your behalf to make it work. If you think it might fit in your 2DIN opening the Housing Dimensions are: W(7") x H(4.3") x D(7.8") also Here.
Related Products...
Infiniti G35 Ashtray Insert
Our Price: $8.99
Add
Our Price: $149.00
Add
BMW E36 LCD Bezel
Our Price: $175.00
Add
BMW E36 LCD Bezel
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Vehicle Specific Parts > Subaru
Monitors and Touchscreens
Monitors and Touchscreens > 7" Touchscreens
Mp3Car Forum Made Products
Lilliput 629GL-70NP 7" VGA Touchscreen $239.99
Panasonic Slot Load CW-8124 DVD-ROM/CD-RW Combo Drive 24x24x24 Disc Drive $45.00
CarNetix CNX-XSC8 Cable Kit for the Xenarc MP-SC8 Power $14.95
