Home > Vehicle Specific Parts >
  2008 Double Din Bolt in kit Without Touchscreen
Our Price: $149.00
Stock Status:(Out of Stock)
Availability:: Ships in 1 to 2 Business Days
Product Code: DSH-016
Description Technical Specs
This kit is compatible with the LED versions of the Lilliput 619 and 629.
This kits does not require modifications to dashboard and can simply be bolted into place. To install, simply bolt it into place. This housing is compatible with the following models:
Impreza WRX/STI      2002-2007
Forester                    2001-2007
Legacy                      2005-2007
Outback                    2005-2007
Baja                          2005-2007
Requires Metra Electronics Kit 99-5807 available from many aftermarket stores.
We have had customers adapt this kit to other vehicles with double DIN openings. Be advised: We are not guaranteeing an exact fit and this may require some modifications on your behalf to make it work. If you think it might fit in your 2DIN opening the Housing Dimensions are: W(7") x H(4.3") x D(7.8") also Here.
Browse for more products in the same category as this item:
Vehicle Specific Parts > Subaru > Subaru Impreza
Vehicle Specific Parts > Subaru > Subaru Legacy
Vehicle Specific Parts > Mazda
Mp3Car Forum Made Products
Direct Fit Double Din LCD Touch Screen for 2004+ Mercedes Benz C Class, CLK, SLK $299.99
DashCommand OBD-II Software $42.99
DTA45 Internal Amplifier 2 x 35W For Nano ITX Enclosure $44.95
DSX12VD 140W DC-DC Regulator $84.99
D945GSEJT Intel Mini-ITX board -Fanless , 2gb Max, 1.6Ghz Atom, sata, 12v $109.99
