Home > Monitors and Touchscreens >
  Extra 629 non-led Lilliput Monitor Casing - Black
Our Price: $20.00
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: MON-048-0001
Description
Need an extra empty casing for a non-LED Lilliput 7" 629 GL monitor? If so, this is for you.
Please note that this casing does not fit LED 629  Lilliput monitors.
Included are the front and back plastic panels and buttons. Bezels come in black or gray color.
Viewable Area: 155mm X 93mm (cut out dimensions for the actual display portion of the screen)
  • Only works with 2007 or earlier non LED liliput displays
  • Might work with 2008 displays. Dremeling, sanding, and removing material will be required.
  • 2008 LED use is at your own risk. No returns, No Refunds, No exchanges
  • Only Back plastic, front platic, and speaker are inclulded
  • No buttons are included.
Included are the front and back plastic panels, there are no buttons included.
Related Products...
Extra Monitor Power Cable
Our Price: $4.99
Add
5 in 1 Lilliput 809 Signal Connector
Our Price: $10.00
Add
7" Touchscreen Replacement for 619 & 629 Lilliput
Our Price: $40.00
Add
7
Lilliput 809 LED VGA Touch Screen TFT LCD Display
Sale Price: $249.00
Add
Lilliput 809 GL 8
Lilliput 16.4 Foot 10-pin din cables for Lilliput
Our Price: $40.00
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Monitors and Touchscreens > Monitor Accessories
Aopen MiniPC plug-and play Power Button Cable Kit for P1900 $14.99
AC/DC Power Brick 120 Volt AC to 12V DC 5Amps $29.99
Lilliput 16.4 Foot 10-pin din cables for Lilliput 629GL-70NP/C/T and 889GL-80NP/C/T $40.00
Fusion Brain Version 4.0 $59.99
ATM 16 Gauge Fuse Holder w/Cover ATFH16MC-10 $0.99
Lilliput 629GL-70NP 7" VGA Touchscreen $239.99
30 Minutes of Consultation ($330 per hour, purchased in 30 minute increments) $165.00
Install Bay 80 Amp Manual Reset Red Button Breaker CB80MR $9.99
