Home > Computer Hardware > Computer Cases >
  Fanless Morex T1610 Mini-ITX Case - White
Alternative Views:
Our Price: $64.00
Stock Status: In Stock
Product Code: ENC-030-W
Description
The Morex T-1610 case is the first one designed to work with the fanless Intel D945GSEJT Mini-ITX board.  The case can rest flat or upright with the includedstand.  It can also be VESA-mounted to the back of an LCD monitor.
Fanless Morex T-1610 Mini-ITX Case - White
Model No.: T1610
Dimensions(mm): 38mm (H) x 178mm (W) x 178mm(D)
Suitable M/B: Intel D945GSEJT M/B
Main Board Size(mm): Mini-ITX Form Factor (170 x 170)
Front Port: N/A
Device Support::
CD / DVD Device: N/A
HDD Device: (1) 2.5" mounting bracket
PCI Slots: N/A
System Fan: N/A (fanless)
Application: Vehicle or Car-PC with Carnetix P2140, Thin Client, Transportation, Networking, All-In-One
Power Supply: (not included in above price)
Optonal Carnetix P2140 (for vehicle/Marine Use) (7.5-34 VDC input) (ignition integrated startup/shut down timer*)
Optional Accessory: AC Adapter (12V/5A)
*ignition integrated startup/shut down timer Requires XC3 Cable) and 3.5mm to MB header assembly (not included)
Related Products...
M350 Universal Mini-ITX enclosure
Our Price: $39.95
Add
Our Price: $64.00
Add
Fanless Morex T-1610 Mini-ITX Case - Black
Morex 5677 Mini-ITX Case Without PSU
Our Price: $55.00
Add
Ampie Car Computer Case
Our Price: $69.95
Add
Our Price: $85.00
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Computer Hardware
New Products
Ampie Car Computer Case $69.95
Infiniti G35 Ashtray Insert $8.99
Lilliput 8" (4:3) VGA Touch Screen TFT LCD Display 809GL-80NP/C/T-BLACK $249.00
7" Touchscreen Replacement for 619 & 629 Lilliput (old version) $50.00
5 in 1 Lilliput 629 Signal Connector $10.00
USB-UIRT (Universal Infrared Receiver/Transmitter) $49.95
Adesso SlimTouch Wireless 2.4 GHz RF Mini Touchpad Keyboard $89.00
2008 Double Din Bolt in kit Without Touchscreen $149.00
