Home > Computer Hardware > Computer Cases >
  Fanless Morex T-1610 Mini-ITX Case - Black
Our Price: $64.00
Stock Status:In Stock
Product Code: ENC-030-B
Description
The Morex T-1610 case is the first one designed to work with the fanless Intel D945GSEJT Mini-ITX board.  The case can rest flat or upright with the included stand.  It can also be VESA-mounted to the back of an LCD monitor.
Fanless Morex T-1610 Mini-ITX Case - White
Model No.: T1610
Dimensions(mm): 38mm (H) x 178mm (W) x 178mm(D)
Suitable M/B: Intel D945GSEJT M/B
Main Board Size(mm): Mini-ITX Form Factor (170 x 170)
Front Port: N/A
Device Support::
CD / DVD Device: N/A
HDD Device: (1) 2.5" mounting bracket
PCI Slots: N/A
System Fan: N/A (fanless)
Application: Vehicle or Car-PC with Carnetix P2140, Thin Client, Transportation, Networking, All-In-One
Power Supply:
Optonal Carnetix P2140 (for vehicle/Marine Use) (7.5-34 VDC input) (ignition integrated startup/shut down timer*)
*ignition integrated startup/shut down timer Requires XC3 Cable) and 3.5mm to MB header assembly (not included)
Browse for more products in the same category as this item:
Computer Hardware
CNX Extra Monitor Power Cable $4.99
USB-SA Andrea External USB Soundcard / SuperBeam Microphone Bundle $44.99
Direct Fit Double Din LCD Touch Screen for 2004+ Mercedes Benz C Class, CLK, SLK $299.99
