http://www.mp3car.com
Home
My Account
Wishlist
My Cart
0 Items: $0.00
Home
Our Products
Fusion Brain Version 4.0
Alternative Views:
Our Price:
$59.99
No Longer Available
Notes:
Hobbyist Grade
Stock Status:(Out of Stock)
Product Code:
COM-089
Cables:
None
3FT USB Type A to B Cable [Add $4.99]
Accessories:
None
DC Power Plug [Add $9.95]
Email me when Back-In-Stock
Description
Extended Information
The Fusion Brain has 16 digital on/off outputs and 13 analogue sensor inputs. The free Fusion Control Centre software from the software section interacts with the board to create the possibility of animated outputs, and graphical input displays. Requires unregulated or regulated 12vDC supply - can be connected straight to car battery, or to regulated 12v source. Can withstand power fluctations from 9v to 15v on the input.
Sensors can be connected to any one of the 13 analogue inputs for readings varying from Temperature to Distance to the amount of Light present.
Relays or LEDs can be connected directly to any of the board's 12 digital outputs header pins allowing for easy installation. Additionally, all 16 outputs are PWM capable. With 500mA of output capacity, each output can drive LEDs or small motors at varying brightness/speeds with from the PWM. With the addition of a MOSFET driver such as the Fairchild FQP50N06, much larger motors can be driven. The FQP50N06, for example, can drive up to 50 amp loads.
Improvements over Brain v3:
16 Digital Outputs
13 Analog Inputs
Selectable Power Source (USB or 12vDC Jack)
30% smaller form factor (70mm X 45mm)
Better power filtering and protection
Ability to update firmware via USB
Ability to update firmware via ICSP header in event of bootloader corruption
Improved signal routing for analog inputs
Pulse Width Modulation, 256 steps with 42uS minimum pulse width (may need firmware update, provided free and uploadable over USB)
Download
The Manual
Related Products...
Box for Arduino
Sale Price: $10.14
Add
Mini-Box picoPSU-90, world's tiniest 12V DC-DC ATX
Our Price:
$35.95
Add
M350 Universal Mini-ITX enclosure (silver)
Our Price:
$39.95
Add
M4-ATX-HV 250W Intelligent DC DC PSU Power Supply
Sale Price: $79.95
Add
Mini-Box picoPSU-120, world's tiniest 12V DC-DC AT
Sale Price: $43.95
Add
Browse for more products in the same category as this item:
Our Products
Our Products
Development Hardware
Dev Hardware
Forum Made Products
Our Products
Peripheral Devices
Our Products
Peripheral Devices
Fusion Brain
Our Products
Mp3Car Forum Made Products
Our Products
Fusion Brain & Accessories
