Home >
  Fusion Brain with DC Power Cable and 2m USB Cable
Fusion Brain
Our Price: $55.99
Notes: Discontinued
Stock Status:(Out of Stock)
Availability:: Ships in 1 to 2 Business Days
Product Code: COM-072
Description Extended Information
The Fusion Brain controls anything with an on/off switch, button, or relay in the car or other mobile environments.
It has 12 digital on/off outputs, 4 digital on/off inputs, and 10 analogue sensor inputs. The Fusion Control Centre software interacts with the board to create the possibility of animated outputs, and graphical input displays. Requires unregulated or regulated 12vDC supply - can be connected straight to your car battery, or to a regulated 12v source. It can withstand power fluctations from 7v to 17v on the input.
Sensors can be connected to any one of the 10 analogue inputs for readings varying from Temperature to Distance to the amount of Light present.
Relays or LEDs can be connected directly to any of the board's 12 digital outputs header pins allowing for easy installation.
Digital inputs can be used for buttons to either send keypresses such as Play, Stop, Pause, Next, Previous to your media player or to turn a digital output on or off.
The Fusion Brain is the best priced, and most feature packed piece of hardware in its category. Use it for home automation, or carPC control, and it seamlessly integrates the computer with the outside world.
Click here to view a comparison table between the Fusion Brain, the Phidgets 8/8/8, the Velleman K8055, and the Zigbee 8
Features
  • Automatic HVAC: Setup automatic climate control in any vehicle to mimic that found in more expensive luxury cars.
  • Ultrasonic Range Sensor:
  • Use inaudible sound waves to determine the distance your car is to
  • other objects. Can be used as a parking sensors, curb sensors, blind
  • spot sensors, and more.
  • 3-Axis Accelerometer:
  • Monitor and record acceleration data on all 3 axii (x/y/z). Designed
  • for the hobbiest to the most serious of racing experts to monitor the G
  • forces on their car.
  • IR Distance Sensor:
  • Precise short distance short field of view sensors are perfect for
  • monitoring distances accurately. Use on air ride suspensions to
  • accurately monitor the exact height of each wheel or anything else.
  • Current Sensor:
  • Monitor the exact amperage used by any device (up to 50 Amps). Curious
  • to see how efficient your amp is, or safety warnings to prevent fuse
  • blowouts before they happen.
  • 100% Anti-Thump Prevention:
  • No more annoying and damaging speaker thump when you use the Fusion
  • Brain! It will not allow the amp to turn on until after the sound
  • drivers are loaded making for a 100% anti-thump solution.
  • Automatic Headlight Control:
  • Automatically adjust highbeams with oncomming traffic, or automatically
  • have your headlights turn on when the sun goes down. The options are
  • limitless.
  • Auto LCD Gamma Control : Have your LCD dim when it gets dark outside so that you arent blinded by an overly bright LCD screen.
  • Physical Rotary Dial:
  • If you miss a physical dial to control your or just want something to
  • compliment the touchscreen, it could not be easier to add it to your
  • CarPC.
  • Touchscreen FriendlySoftware:
  • Big buttons and light CPU load make for the perfect CarPC application
  • to be used with touchscreens as well as lowend Via embedded
  • motherboards.
Fanless Morex T-1610 Mini-ITX Case - Black $64.00
CNX Extra Monitor Power Cable $4.99
USB-SA Andrea External USB Soundcard / SuperBeam Microphone Bundle $44.99
