Home > Our Products > Audio, Radio, and Video >
  GIGAPort AG USB Sound Card with 8 Channel audio output!
Alternative Views:
Not just another USB peripheral, GigaPort AG is the first of its kind, offering eight channels of audio output to eight individual analog outputs. The versatility of USB means that now you can have a viable high quality audio connection going out of your laptop or any USB compatible computer to the destination of your choice. And since GigaPort AG supports ASIO 2.0, GigaPort AG is compatible with both MAC and PC.
USB to 8 channel!
The GIGAPort AG is equipped with eight RCA analog outputs, which make the possibilities endless. With eight high quality outputs, you could be mixing directly to DVD, transferring files, or just kicking back listening to your favourite DVDs straight out of your laptop in full 5.1 surround.
Specifications.
- 8 x RCA Analog Output (8 x 24 bit D/A Converter)
- SPDIF Optical Output
- One Headphone Out
- WDM driver for Windows®XP/2000/ME/98SE
- ASIO2.0 driver for Mac OS 9.x & Windows®OS
- MAC OS X compatible
Our Price: $129.95
Stock Status:(Out of Stock)
Product Code: COM-066
Description Technical Specs Extended Information
The GIGAPort AG is an USB to analog 8 channel audio Interface with one Optical output.
Features
It is simple, tiny, and fast.
The GIGAPort AG can be used with your digital audio recording software to playback stereo digital audio source with exceptional audio quality.
USB stands for Universal Serial Bus, which means it connects peripherals to a computer. It is an evolved form of old serial or parallel bus.
USB makes installation of new peripherals much simpler, just plug and play. You don’t have to open the PC to add a peripheral any more, just plug and turn it on. With USB-compliant computers and peripherals, there are no more worries about IRQ setting, DIP switch setting, or card installation. Even the computer turned on, it is no problem with attaching and removing devices. Just plug and play!
Practically, there is no limit on number of devices that can be linked to the computer using USB hubs.
USB even provide electrical power and supplies it, which eliminates messy power cables from working space.
If you are a professional or in need of a professional quality USB audio interface, you have made a sound investment in the GIGAPort AG.
8 Channels of Analog output: The GIGAPort AG provides 8 channels of RCA analog outputs for playing back multi tracks of popular Software Synths and Sampler. All 8 channels have their own green LED for display output signals.
SPDIF Optical Output and Headphone Output
: GIGAPort AG also provides Optical output and Headphone output. This Optical output is same as analog outputs 1,2 of the GIGAPort AG.
Portable Design: The GIGAPort AG’s compact design allows you to take your project on the road anywhere and everywhere you want to go.
Easy to install, simple to operate: Just plug the GIGAPort AG’s USB connector into your computer and the other end into devices such as a recorder or mixer and you’re set to go.
Virtual Instruments ready: The GIGAPort AG is custom made for you to get the most out of your software synths and samplers.
ASIO Empowered (Currently unavailable in Windows XP)
The GIGAPort AG is the perfect match for ASIO driver software like CUBASE, NUENDO, REACTOR, REASON and LOGIC.
GSIF support for TASCAM GigaStudio’ and ‘ASIO driver support with Windows XP’ are in development.
Browse for more products in the same category as this item:
Our Products
