Home > Power > Intelligent Automotive ATX Power Supplies >
  GP83 160W Intelligent DC-DC PSU
Our Price: $69.99
Sale Price: $39.99 No Longer Available
You save $30.00!
Stock Status:(Out of Stock)
Availability:: Ships in 1 to 2 Business Days
Product Code: PWR-032
Description Technical Specs
The GP83 is our newest mini ITX power supply.  Providing 160W of maximum power output, the supply is suitable for a wide variety of mobile computing applications.  The PSU includes a momentary push button reset switch and a green power-on indicator LED pictured below.
Features
-Wide input voltage range 8V ~28V, max. output power is 160W.
-Multi standby modes can be choosed through the button on GP-83
  or LED controller.
-Capable of controlling amplifier by remote ON/OFF.
-'Anti-thump' function enable starting your PC in peace when the
  PC is connected to the amplifier.
-Intelligent shutdown function in order to prevent 'deep discharge'
  situations.
-Ignition Timing feature can prevent your PC from continually
  consuming power when standby.
-HARDOFF enable your PC shut down in sequence so that secure
  your system data.
-Work with all mini-itx boards.
-Applied with special input header in case cable dropout occurs.
  Specification
-Dimensions (mm): L160 x W45 x H21
-DC Input Voltage: 8V ~ 28V
-Deep-Discharge Shutdown Threshold: 11.2 V
-Input current limit: 15A
-Max Output Power: 160W
-Storage temperature: -55 to 125 ℃
-MTBF: 192,000 hrs @ 50C, 96,000 hrs @65C
-Efficiency (Input 9-16V) : above 94%
-Output Cables: 2 big 4pin to 2 small 4pin
Browse for more products in the same category as this item:
Power
Fanless Morex T-1610 Mini-ITX Case - Black $64.00
CNX Extra Monitor Power Cable $4.99
USB-SA Andrea External USB Soundcard / SuperBeam Microphone Bundle $44.99
