Home > Vehicle Computers >
  Habey BIS-6625-II-E640 Intel Low Power PC Can Bus, WIFI, 3G, 4G
Alternative Views:
Our Price: $439.95
Stock Status:In Stock
Product Code: CCC-221
Keyboards:
   One of the nicest and most compact wireless keyboards with a touchpad we've found!
WiFi:
Bluetooth:
Description
Habey's newest mini PC features dual sim slots for 3G and 4G connectivity, Wi-Fi support, and an internal CAN Bus connection for automotive applications.
  • Ultra-compact for space-constrained applications
  • 3 internal mini PCIe slot with SSD support option
  • Low power consumption and fanless design
  • Dual SIM slots for 3G/4G connectivity
  • Dual Gigabit Ethernet ports and WIFI support
  • VESA mount ready for easy installation and mounting
  • VGA Video out Display
  • 4 built-in internal COM ports
  • internal CAN Bus connection for automotive applications
Install your hard drive, your OS and front end, and you're ready to go.  It takes regulated 12V power so the CarNetix CNX-P2140 would be an obvious choice for intelligent DC power. Dare we suggest this might easily fit behind your double din LCD touch panel?
The BIS-6625-II-E640 is a fanless full-featured industrial PC.  Its ultra-compact, fanless housing is based on Habey's highly efficient proprietary  thermal design.  The bold-on VESA mounted design makes it easier to convert any standard VESA display into an all-in-one PC with only four screws, no extra brackets needed.
The Habey's integrated video decoder is able to accelerate major video formats including H264, MPEG2, VC1, and WMV9, eliminating the need for software decoding and off-loading the processor.  Total power consumption is only 5.5W.  The compact, fanless system with enhanced video performance makes it the ideal platform for small form factor PC media player, kiosk, proximity, digital signage, POS, thin-client applications in space-constrained, mobile, and extended temperature environments.
Features
BIS-6625-II
Processor
Intel Atom E640 1.0GHz
PCH
Intel Platform Controller Hub EG20T
RAM
Onboard DDR2 1GB
Display
Display Interface
VGA via SDVO with max resolution of 1920x1080@85Hz
Graphic
Integrated 2D/3D Graphics Engine 400MHz
Supports OpenGL ES2.0, OpenVG1.0, DirectX9.L
Hardware Decoder
Full hardware acceleration of H.264, MPEG2, MPEG4, VC1, and WMV9 up to 1080i @ 30fps
Hardware Encoder
Full hardware acceleration of H.263, H.264, and MPEG4 up to 720p @30fps (Linux)
Storage
Flash
HDD
1x 2.5” internal HDD/SSD bay, support SATA II (HD Required)
System I/0
PS/2
COM
4x COM (internal) via pin header; 1 full RS232; 3x Tx & Rx only
CAN
CAN Bus via internal header; Supports CAN protocol version 2.0 part A and B via PCA82C250T
USB
2x Front USB2.0, 3 x Rear USB2.0
Audio
Integrated Intel Hi-Definition Audio
1x Mic-in, 1x Line-out interface
Wireless
Optional via internal USB module
LPT
Ethernet
2x GbE, 2x RJ45, Realtek RTL8211CL + RTL8111D
Expansion
3x mini PCIE slot with SSD support option, 2x SIM Slot
System Control
Power On/Off
LED Indicator
Power and HDD indicator
Power Supply
DC +12V
Cooling System
Proprietary fanless thermal design
OS Support
Supports Windows Embedded Standard 2009/7/POS Ready 2009/CE 6.0 R3, Windows XP SP3/7, Fedora Core 11 Linux*, MeeGo 1.0, QNX Neutrino, Wind River VxWorks
Mechanical & Environmental
Operational temperature
-10 ºC - 50 ºC (14ºF - 122 ºF)
Storage Temperature
-40 ºC - 60 ºC (-40ºF - 140 ºF)
Humidity
5%95%, 40 ºC, non-condensing
Vibration
0.5g rms/5~500Hz/ random operation
EMC
CE/FCC Class B
Dimension
125mm×125 mm×45 mm (W×D×H)
Net weight
2 lbs
Materials
Aluminum + Steel
Coating Processes
Aluminum Oxidation
Mounting
VESA Mount Ready (100mm x 100mm)
 * Linux support is based on chipset manufacturers’ published driver support. If it is Intel chipsets, the drivers can be found at: http://edc.intel.com/Software/Downloads/.  Other non Intel chipsets, please contact HABEY for availability.  HABEY does not provide support on driver installation of published drivers from chipset manufacturers or compatibility test with other Linux distributions without published drivers.
Browse for more products in the same category as this item:
Vehicle Computers
Vehicle Computers > Enthusiast Car Computer Systems
New Products
Vehicle Computers > Embedded & Industrial Computers
