Home >
  Heyco Grommet & Liquid Tight cordgrip - 0.395" inside diameter
Alternative Views:
Our Price: $5.00
Stock Status: In Stock
Product Code: CBL-077
Description
Heyco Liquid Tight Cordgrip Straight-Thru, PG Hubs
For Flexible Cords. For use in clearance or threaded holes.
  • 10mm or 0.395" max cable diameter
  • .23" or 5.8mm min cable diameter
  • Multiple sizes for cable diameters ranging from .064˝ (1,6 mm) to 1.730˝ (44,0 mm)
  • We recommend using the fitting with the smallest maximum diameter that will fit your application
  • Acme threads on body prevent skipping and speed installation.
  • All nylon construction with TPE or Buna N Sealing Gland resists salt water, weak acids, gasoline, alcohol, oil, grease, and common solvents. This feature is not assessed by UL.
  • TPE Sealing Gland is used in LTF Series. Buna N Sealing Gland is used in LTCG Series
  • PG hub threads are steel conduit threads per DIN 40430.
  • Suitable for NEMA type 6 enclosures. Locknuts INCLUDED.
  • Certified by Canadian Standards Association File LR93876C
  • Recognized under the Component Program of Underwriters’ Laboratories File E51579
  • Listed under Underwriters’ Laboratories File E51579
  • 6/6 Nylon with Buna N Sealing Gland (LTCG Series) or TPE Gland (LTF Series)
  • Flammability    94V-2
  • Temperature    -22°F (-30°C) to 212°F (100°C)
 Share your knowledge of this product with other customers... Be the first to write a review.
