Home > Monitors >
  High Brightness Lilliput 869GL-80NP/C/T-HB 8" Touch Screen LCD Monitor DVI HDMI
Alternative Views:
Our Price: $209.00
Stock Status:In Stock
Product Code: MON-137
Description Extended Information
High Brightness version.  350 Nits.  HDMI makes it possible to run a long cable to your monitor without encountering the possible flickering associated with analog connections.  Good contrast and rich, deep colors are possible with this digital connection.  High quality Lilliput design and build characteristics.
Features
  • 4 wire resistive touch panel
  • HDMI/DVI input
  • Touch screen control
  • With VGA input, connecting directly to PC, as a Personal Computer
  • With AV input, connecting directly to DVD player, as a car entertainment system
  • With touch screen operation, can as a display terminal unit of industrial equipment
Specifications
  • Panel Size: 8" TFT LCD
  • Type:  a-Si TFT active matrix
  • Native Resolution: 800X3(RGB)X480
  • Aspect Ratio:  16:9
  • Touch Panel: 4-wire resistive
  • Brightness: 350 CD/Mē
  • Contrast: 300:1
  • Viewing Angle: 65/65 (Left/Right) and 45/65 (Up/Down)
  • Input Voltage: DC 12V
  • Input Signal: PC(VGA), AV1, AV2, HDMI, DVI
  • Power Consumption: 8W
  • Audio Output: 1W
  • Size(LWD): 211 x 136 x 31mm
  • Weight: 560g
  • Viewable area is 176.64(W)X99.36(H) mm.
Packing Details
  • Monitor
  • Power Cable
  • 15-pin D-sub Cable
  • Stand
  • Remote
  • Manual
  • Drive Disk
Browse for more products in the same category as this item:
Monitors
Monitors and Touchscreens
Monitors and Touchscreens > 8" Touchscreens
Monitors and Touchscreens > Lilliput
