Home > Monitors >
  IEI 15" Industrial TDM-150GMS XGA LCD Monitor USB Touch Screen Interface 9-36V input voltage
Picture depicts 12" Model
Our Price: $1,425.99
Stock Status:In Stock
Product Code: MON-113
Description Extended Information
Usually Ships Within 3 Weeks
IEI Industrial 15" USB Interface Touch Screen Monitor.  Typical monitors can only be used in environments that have temperatures in the 0C~50C range.  Extended IEI environmental testing is performed to ensure the TDM series continues to function properly over its entire service life in a wide working temperature range of -30C to +70C. After being tested in the -30C to +70C temperature range, the TDM series was found to maintain its original luminance.
The TDM-121GMS supports higher resolutions and smaller pixel pitches to deliver great computer displays.
With a luminance of 450 cd/m^2, the TDM series offer an improvement over the 250 to 300cd/m^2 luminance typically available with other 15-inch TFT LCD modules. The high-brightness feature ensures the screen content is highly visible in all lighting conditions.
Typical small size monitors only support 130/110 (H/V) viewing angle, but IEI TDM series can support maximum of viewing angle up to 160/160 (H/V).  Wide viewing angles let you not lose the screen brightness and possibly a change of displayed colors, when you view the monitor from the side.
Features:
1. Wide Operating Temperature: -30C~+70C
2. 12.1'' XGA High Resolution
3. Superior Image
4. M models support 9~36V DC power input for mobile application
5. DVI-D and Analog VGA input interface for comprehensive usage
6. IP 65 Compliant
Includes:
1  TDM LCD monitor
1  Power cable for terminal block
1  VGA cable
1  User manual on CD-ROM
1  Screw set
1  Touch Panel RS-232 Cable/Touch Pen/Driver CD-ROM (For T-R model only)
1  45W AC power adapter / AC power card (Operating Temperature : 0C~ +40C)
Model Number: TDM-150GMS-USB-R11/T-R
LCD Size    15"
Input Interface    Analog VGA+DVI-D
Max Resolution    1024 x 768(XGA)
Brightness (cd/㎡)    450
Contrast Ratio    700:1
Display Color    16M
Pixel Pitch (mm)    0.297
Front Frame    Aluminum
Chassis    Heavy-duty Steel
View Angle (H/V)    160/160
Backlight MTBF(Hrs)    50000hrs
Input Voltage    +9~+36V DC power input
OSD function    Yes
Smart OSD    Yes
Mounting    Wall/Panel/Rack/Arm/Stand
Color    Silver
Dimension(W x H x D mm)    410 x 309 x 65.2
Operating Temperature    -30C ~+70C
Storage Temperature    -40C ~ +80C
Front Panel Protection    IP65 Compliant
Net Weight    6kgs
Browse for more products in the same category as this item:
Monitors
Monitors and Touchscreens
Monitors and Touchscreens > IEI
