Home > Monitors >
  Inelmatic Industrial Grade 10.4" TFT-LCD Sunlight Readable Touch Screen Monitor XF1000
Alternative Views:
Our Price: $1,199.95
Stock Status:In Stock
Product Code: MON-128
Description
Our Industrial Grade Sunlight Readable VGA 10.4" Touch Screen Monitor is a perfect fit in applications where durability and readability are of paramount importance. Applications include personal vehicles, public transportation vehicles (buses, taxis, public fleet), public service vehicles (police, fire, ambulance, and other public fleet) and any other situation where a small footprint and image quality are important. This monitor performs well even in direct sunlight or strong ambient light. Color depth and contrast are exceptional. Our XF1000 is LED backlight, optically matched, and has very high brightness (1000nits).
In addition, the XF1000 includes the latest generation of LED backlighting, with passive enhancement to achieve high brightness, while allowing the lowest possible power consumption. Additionally, the dimmer allows one the possibility of matching the brightness to the ambient light. This makes the display able to work in the darkest conditions without disturbing the driverís visibility. It also allows high brightness for intense lighting environments.
The touch panel has a USB interface.
  • Inelmatic XF1000HB-USVA2-NB-R
  • High brightness
  • Ultra-low power LED backlight.
  • Sun-readable available.
  • 5 Step backlight dimmer.
  • Auto power on/off by VGA signal.
  • Two composite video input.
  • One composite video input with mirror option.
  • All in one cable, 2.5 and 4.5m length options.
  • Power 6-36V, meets car/truck requirements, including noise/spikes filters.
  • Ultra low power consumption.
  • Wide temperature range.
  • Shock/Vibration proof.
  • Aluminum chassis and rear side.
  • 1000 nits
  • Optically Matched
  • LED backlight
  • 2 Year Limited Warranty through Inelmatic
Aspect
4:3
Colors
256K
Native Resolution
1024 x 768
VGA Modes
640 x 480 to 1920 x 1440
Contrast
700:1
Inputs
VGA
Audio
2 x 1.8W (stereo)
Touch Panel
Resistive 4 Wires. Endurance > 2M
Power Supply
6-32VDC automotive suitable
Power Consumption
8W
Dimensions
248mm x 185mm x 31mm
Enclosure
Aluminum Rear Chassis, PVC-ABS Front Chassis
Operating Environment
-30C to 80C max (-20C to 60C Continuous)
Storage Temperature
-30C to 80C
Vibration
1G 2-500Hz
Shock
20G 11ms
Drop
10cm Max
Browse for more products in the same category as this item:
Monitors
Monitors and Touchscreens
Monitors and Touchscreens > 10" Touchscreens
Monitors and Touchscreens > Sunlight Readable
