Home > Our Products >
  Infrared Waterproof Surface Mountable CCD Backup Camera
Our Price: $49.95 No Longer Available
Stock Status:(Out of Stock)
Product Code: COM-129
Description
The car rear view camera is made of weatherproof aluminum casing with a detachable mounting bracket for easy installation. High resolution CCD image sensor produces excellent color video in the day and automatically turns to B/W mode in the night.  Avoid accidents, hook up your trailer easily, or increase rearward visibility on your primary vehicle.  Requires 12V power.
Sensor Sharp CCD
Effective Pixels
512 x 582
  512 x 492
Vertical Sync Frequency
50Hz
60Hz
Horizontal Sync Frequency 15625kHz 15734kHz
Scanning Frequency 2:1 Interlace
Sync System Auto
AGC/BLC Auto
Resolution 420 TV Lines
Video Out 1.0V p-p, 750Ohm
S/N Ratio <48db
Current Consumption Max 300mA
Power Input DC 12v  ±20% (9.6vDC-14.4vDC)
Operating Temperature -20°C- 70°C RH 95% Max
Storage Temperature -40°C- 85°C RH 95% Max
Lens Angel 120°
Horizontal Angel 110° 108°
Waterproof Intrusion Protection Rating IP68 (Totally dust and waterproof)
IR LED's 10 pcs with Ambient Light Sensor
Minimum Illumination 0 LUX
Video Input Composite/RCA (Wiring Included)
Power Input 2.5mm Barrel Connector (+inside/-outside) Wiring Included
Dimensions Main Housing: 27.8mm
Total Length: 69mm (including wiring)
Width: (front of lens) 31.5mm
Browse for more products in the same category as this item:
Our Products
Our Products > Audio, Radio, and Video
Our Products > Audio, Radio, and Video > Cameras
Our Products > Peripheral Devices
