Home > Computer Hardware > Motherboards >
  New Intel D201GLY2A Little Valley with 1.33 GHz Celeron Processor (Fan Cooled)
Our Price: $74.99
Notes: Discontinued
Stock Status:(Out of Stock)
Availability:: Ships in 1 to 2 Business Days
Product Code: MTB-054
Accessories:
Description Technical Specs Extended Information
The D201GLY2A is an economical mainboard backed by the Intel brand of quality and performance. The first Mini-ITX form factor offered direct from Intel, the D201GLY2A is energy-efficient (requiring less than 27W of power) and has improved thermal/acoustic characteristics over standard desktop mainboards. This mainboard comes in bulk packaging.
The D201GLY2A is the same as the D201GLY2 except that the processor is fan cooled as opposed to being passively cooled by a heat sink only in the D201GLY2
See the comparison chart for the Y2 and Y2A we have created on the Forums!
Features
  • With
  • 1.33 GHz Celeron 2xx processor; has PCI, VGA, Parallel port, and 6 USB
  • 2.0 support. First Mini-ITX mainboard produced by Intel. Bulk Packaging.
    Intel®
  • Desktop Board D201GLY2A will change the way you use personal computers.
  • This new generation of Intel Desktop Board bring an integrated board
  • and processor solution to the ultra-value market segment for the first
  • time. The innovative design of Intel Desktop Board D201GLY2A provides a
  • low-cost, low-power consumption board in a mini-ITX/microATX-compatible
  • form factor. This easy-to-use Intel Desktop Board meets all your
  • computing needs, including email and Internet access, instant messaging
  • (IM), and Voice over Internet Protocol (VoIP). The easy-to-configure
  • basic features of Intel Desktop Board D201GLY2A allow you to meet your
  • local integration and installation requirements, and offer the high
  • level of quality users have come to expect from an Intel Desktop Board.
    The Intel® Board D201GLY2A includes:
    • Integrated Intel® Celeron® Processor
    • ATA 100/66 and SATA Cable
    • Back Panel I/O Shield
    • Board Layout Sticker
    • Quick Reference Guide
    • Intel® Express Installer Driver and Software CD
    1 Intel® Celeron® Processor: Integrated, low-power processor with 533 MHz system bus.
    2 SiS662* chipset featuring SiS Mirage Graphics*: A low-cost graphics solution.
    3 Single DIMM socket: Designed to support up to 1 GB of DDR2 533 / 400 SDRAM.
    4 PCI slot: Expansion slot for custom system configurations and future add-in card upgrades.
    5 IDE connector: Supports up to two ATA 100/66 devices.
    6 Integrated 10/100 LAN: On-board 10/100-Mb/s Ethernet LAN connectivity.
    7 AC’97 Audio: Integrated stereo audio at an excellent value.
    8 Support for up to six Hi-Speed USB 2.0 ports: Two back panel ports and two front panel headers supporting four additional USB 2.0 ports.
    9 Mini-ITX/microATX compatible form factor
    10 Two Serial ATA ports (1.5 Gb/s)
    (Photo of USB port accessory below)
    USB Ports Supersize Accessory
Browse for more products in the same category as this item:
Computer Hardware > Motherboards > Intel
Computer Hardware
Sunlight Readable Industrial Grade 7" VGA Touch Screen Monitor Inelmatic $749.99
Habey BIS-6620-I Intel Embedded Z510 Based Ultra Low Power "Tiny" PC $304.99
