Home > Our Products > Computer Hardware > Hard Drives >
  Intel X25-E Extreme 2.5" 32GB SATA II SLC Solid State Drive SSD
Our Price: $415.00
Stock Status:In Stock
Product Code: HRD-042
Description
"Everything you need to know about Solid State Disks (SSD)"
- X25-E Mainstream Intel 32GB Solid-State Drive
Intel high performance Solid-State Drives (Intel SSDs) are designed to deliver outstanding performance and reliability. With no moving parts, Intel SSDs offer a quiet storage solution that responds quickly and uses less power. Compared to traditional hard disk drives, Intel SSDs are significantly more responsive, much more reliable, have lower power consumption and are completely quiet.
Intel SSDs are designed and validated specifically for PC applications using Intel's deep knowledge and understanding of PC design.
General
Device Type Solid state drive - internal
Hard Drive
Form Factor 2.5"
Capacity 32 GB
Interface Type Serial ATA-300
Features Native Command Queuing (NCQ)
Compliant Standards S.M.A.R.T.
Reliability
MTBF 2,000,000 hour(s)
Expansion / Connectivity
Interfaces 1 x Serial ATA-300
Compatible Bays 1 x internal - 2.5"
Miscellaneous
Works with Windows Vista Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Compliant Standards CE, UL, C-Tick, BSMI, WHQL, MIC, RoHS
Environmental Parameters
Min Operating Temperature 32 °F
Max Operating Temperature 158 °F
Shock Tolerance 1000 g @ 0.5ms (operating) / 1000 g @ 0.5ms (non-operating)
Vibration Tolerance 2.17 g @ 5-800 Hz (operating) / 3.13 g @ 10-500 Hz (non-operating)
Browse for more products in the same category as this item:
Our Products > Computer Hardware > Hard Drives > Automotive
