Home > Monitors >
  Lilliput 12.1" 16:9 SKD Open Frame Touch Screen VGA, HDMI, & DVI Monitor
Alternative Views:
Our Price: $319.95
Stock Status:In Stock
Product Code: MON-133
Description
Good for industrial, embedded, and digital signage applications. If you need a solution integrated into your own custom enclosure, this may be the monitor for you. The disassembling work is already done for you. Simply install this into your custom enclosure or dash panel kit.
  • 12.1" 16:9 LCD Monitor with VGA and Composite Input.
  • Resolution: 1280 800, Displays up to 1920 x 1080
  • VGA input
  • DVI Input
  • HDMI Input
  • USB Touch Screen interface
  • Composite Viedo Inputs
  • Audio Input
  • Built-in multi-language OSD
  • Remote control
  • Wire Wire Touch Screen
  • Display Screen: 12.1 Inch TFT LCD
  • Resolution: 1280 800(3,072,000 ) pixels
  • Color System: PAL-4.43 NTSC-3.58
  • Ratio Aspect: 16:9
  • Contrast Ratio: 500:1
  • Brightness: 200cd/m2
  • Viewing Angle: 20/40(U/D),40/40(L/R)
  • Input Voltage: DC 11-13V
  • Power Consumption: ≤15W
  • Dimension(mm): 275.82L 178W 5.2H
Includes:
  • HDMI/ DVI Cable: 1 Piece
  • DC 12V Power Adapter: 1 Piece
  • Remote Control:1 Piece
  • 12V Car Power Adapter: 1 Piece
Browse for more products in the same category as this item:
Monitors
Monitors and Touchscreens
Monitors and Touchscreens > Lilliput
Monitors and Touchscreens > 12" Touchscreens
