Home > Monitors and Touchscreens > 7" Touchscreens >
  Lilliput 629GL-70NP 7" VGA Touchscreen w/ Auto Back-up Camera Switch
(Simulated image closely resembles the difference in old and new model)
Our Price: $259.99 Special price for a limited time, see product description.
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: MON-016-0002
Accessories:
Description Technical Specs Extended Information
Take $25 off the price of this product.
Use coupon code, HOLIDAY09, upon checkout to receive the discount.
Offer expires November 23, 2009.
This Lilliput is prewired for an automatic backup camera switching function.  There is a 12V wire lead that, when power is supplied to it, switches the input to the red RCA input jack.  This is perfect if you want your backup camera to appear on the Lilliput every time you shift into reverse.
This Lilliput 629GL-70NP monitor is a popular screen for the automotive computing environment, however it may also be used in the home as it comes with an AC-DC power plug. What makes it so special is that it’s VGA so therefore it’s high resolution. Text is readable, great for GPS applications. Another feature that sets this screen apart is its touch screen which makes it easy to control your computer. Applications include: computer display, DVD, VCD, security systems, navigation systems and also rear view cameras.
Mp3Car Review: The new Lilliput 629GL-70NP monitor is LED backlit. This allows for the monitor to consume less power and have a higher contrast ratio of 500:1. This will drastically improve visibility in sunlight. It is still not transflective but very nice for $500 dollars less. The new monitor will also operate in cooler temperatures without a long warm-up time to peak brightness. Overall Lilliput has made some drastic improvements to the 629GL that enable it to be a great addition to any computer system.
Informative Threads:
Features
Touch Screen: four-wire resistive touchscreens
Inputs: 1 VGA input and 2 RCA inputs, 1 AUDIO input
Built-in Speaker
Infrared Remote Control
Input Voltage: DC 11-13V
Power Consumption: <8W
  • Screen size: 7 inches diagonal
  • Physical dimensions (in): 7.33W x 5H x 1.5D
  • Ratio: 16:9 wide TFT screen
  • Native Resolution: 800x480
  • Resolution Range: 640x480 up to 1280x1024
  • Dot Resolution: 2400 x 480 (= 1,152,000 dots)
  • Color configuration: RGB stripe
  • Video system: PAL/NTSC
  • 2 Video inputs plus 1 Audio input
  • VGA input
  • Touchscreen display (USB interface)
  • IR remote control
  • Full function OSD control (Multi-language)
  • Audio output: Speaker built-in
  • Video input signal: 1.0Vp-p, composite video
  • High resolution and no radiation
  • Computer display/S-video/DVD/VCD/Security system/Navigation system compatible
  • (Rear view camera connectible)
  • Mount type: Dash board
  • Power input: DC 12V
Whats in the box:
AC Adapter
DC 12V Car Power Cord
A/V Cable
VGA and USB combined Cable
Remote Controller
Driver Disk for touch screen
AUTO Bracket  (Stand)
Operation Manual
Related Products...
New! 7'' Transflective LED Backlit Sunlight Readab
Our Price: $729.99
Add
New! Mp3Car 2008 7'' Transflective LED Backlit Sunlight Readable Monitor
Our Price: $239.99
Add
Lilliput 7" VGA Touchscreen 619GL-70NP
Our Price: $224.99
Add
Lilliput 7
Xenarc 705TSV 7" TFT LCD Touchscreen Monitor
Our Price: $269.99
Add
Xenarc 705TSV 7
Xenarc 702TSV VGA Touchscreen Monitor
Our Price: $484.99
Add
 Share your knowledge of this product with other customers... Be the first to write a review.
Browse for more products in the same category as this item:
Monitors and Touchscreens > Lilliput
Additional Shipping Costs $360.00
USB-SA Andrea External USB Soundcard / SuperBeam Microphone Bundle $44.99
D945GSEJT Intel Mini-ITX board -Fanless , 2gb Max, 1.6Ghz Atom, sata, 12v $119.99
Xenarc 700IDT 7" In-Dash LCD Touch Screen Monitor $415.00
Power Bundle - Mobile Car Computer System $629.99 Please allow up to 3 business days for processing.
