Home > Monitors and Touchscreens > 7" Touchscreens >
  Lilliput 629GL-70NP/C/T 7" VGA Touchscreen w/ Auto Back-up Camera Switch
Our Price: $249.99
Sale Price: $199.95
You save $50.04!
Stock Status:In Stock
Product Code: MON-016-0002
Accessories:
Description Technical Specs Extended Information
This Lilliput is prewired for an automatic backup camera switching function.  There is a 12V wire lead that, when power is supplied to it, switches the input to the red RCA input jack.  This is perfect if you want your backup camera to appear on the Lilliput every time you shift into reverse.
This Lilliput 629GL-70NP monitor is a popular screen for the automotive computing environment, however it may also be used in the home as it comes with an AC-DC power plug. What makes it so special is that it’s VGA so therefore it’s high resolution. Text is readable, great for GPS applications. Another feature that sets this screen apart is its touch screen which makes it easy to control your computer. Applications include: computer display, DVD, VCD, security systems, navigation systems and also rear view cameras.
Mp3Car Review: The new Lilliput 629GL-70NP monitor is LED backlit. This allows for the monitor to consume less power and have a higher contrast ratio of 500:1. This will drastically improve visibility in sunlight. It is still not transflective but very nice for $500 dollars less. The new monitor will also operate in cooler temperatures without a long warm-up time to peak brightness. Overall Lilliput has made some drastic improvements to the 629GL that enable it to be a great addition to any computer system.
Informative Threads:
Features
  • Touch Screen: four-wire resistive touchscreens
    Inputs: 1 VGA input and
  • 2 RCA inputs, 1 AUDIO input
    Built-in Speaker
    Infrared
  • Remote Control
    Input Voltage: DC
  • 11-13V
    Power Consumption: <8W
    • Screen size: 7 inches diagonal
    • Physical dimensions (in): 7.33W x 5H x 1.5D
    • Brightness:  300 cd/m2
    • Ratio: 16:9 wide TFT screen
    • Native Resolution: 800x480
    • Resolution Range: 640x480 up to 1280x1024
    • Dot Resolution: 2400 x 480 (= 1,152,000 dots)
    • Color configuration: RGB stripe
    • Video system: PAL/NTSC
    • 2 Video inputs plus 1 Audio input
    • VGA input
    • Touchscreen display (USB interface)
    • IR remote control
    • Full function OSD control (Multi-language)
    • Audio output: Speaker built-in
    • Video input signal: 1.0Vp-p, composite video
    • High resolution and no radiation
    • Computer display/S-video/DVD/VCD/Security system/Navigation system compatible
    • (Rear view camera connectible)
    • Mount type: Dash board
    • Power input: DC 12V
  • Whats in the box:
    AC Adapter
  • DC 12V Car Power
  • Cord
  • A/V
  • Cable
  • VGA and USB combined
  • Cable
  • Remote
  • Controller
  • Driver Disk for touch screen
  • AUTO
  • Bracket  (Stand)
  • Operation
  • Manual
Browse for more products in the same category as this item:
Monitors and Touchscreens > Lilliput
Lilliput FA1042-NP/C/T Touchscreen 10.4 inch 4:3 Desktop/Wallmount LCD VGA Monitor $245.95
Ivtek SSD High Definition HD Video Recorder iVox-102H $299.95
Intelligent DC-DC Converter with USB Interface $59.95
