Home > Monitors >
  Lilliput 669GL-70NP/C/T-5HB 7" HDMI, DVI, VGA High Brightness, 5 Wire Resistive Touch Screen
Lilliput 669GL-70NP/C/T-5HB 7" HDMI, DVI, VGA High Brightness 5 Wire Resistive Touch Screen
Alternative Views:
Our Price: $299.95
Sale Price: $244.95
You save $55.00!
Stock Status:In Stock
Product Code: MON-123
Description Technical Specs Extended Information
Introducing Lilliput's latest rendition of a 7" touch screen monitor with HDMI, DVI, and VGA inputs.  50% brighter than the standard 669GL-70NP/C/T.  5 wire resistive touch screen instead of 4 with the standard 669 makes touch input control more precise.    HDMI makes it possible to run a long cable to your monitor without encountering the possible flickering associated with analog connections.  Good contrast and rich, deep colors are possible with this digital connection.  High quality Lilliput design and build characteristics.
Standard Lilliput 669-70NP/C/T on left.  High brightness model on right.
High brightness model has slightly less reflection and more vivid color.
Specifications
  • LCD Size:  7" diagonal
  • Backup Camera Auto Switching Wire is Exposed
  • Type:  a-Si TFT active matrix
  • Native Resolution:  800 x 3(RGB) x 480
  • Active Area:  152.4mm (W) x 91.44mm (H)
  • Dot Pitch:  0.0635mm(W) x 0.1905mm(H)
  • Aspect Ratio:  16:9
  • Brightness:  High Brightness 450 CD/M�
  • Contrast Ratio: 500:1
  • Light Source:  LED
  • Surface Treatment:  Anti-Glare
  • Viewing Angle:  70/70 (left/right) and 50/70 (up/down)
  • Video input Signal:  VGA, RCA, HDMI, DVI (requires adapter)
  • Compatibility:  PC, MAC
  • Input: 1 VGA, 2 RCA Video, 1 RCA Audio input, 1 HDMI or DVI
  • Power:  AC to DC power adapter (Input: 100-240V, 50/60Hz, 0.60A Output: 12V, 1200mA)
  • Power Consumption: <8 Watts
  • Touch Screen:  Five Wire Resistive Touch
  • Touch Interface:  USB or RS232
  • Speaker:  Built in, 1 Watt
  • Remote Control:  Infrared
  • Stand:  Detachable, Swivel, Tilt
  • Storage Temperature:  -20C to 70C
  • Operating Temperature: -10C to 60C
Browse for more products in the same category as this item:
Monitors
Monitors and Touchscreens
Monitors and Touchscreens > Lilliput
Monitors and Touchscreens > 7" Touchscreens
