Introducing Lilliput's first monitor with HDMI, DVI, and VGA inputs. HDMI makes it possible to run a long cable to your monitor without encountering the possible flickering associated with analog connections. Good contrast and rich, deep colors are possible with this digital connection. High quality Lilliput design and build characteristics.
Specifications
- LCD Size: 7" diagonal
- Type: a-Si TFT active matrix
- Native Resolution: 800 x 3(RGB) x 480
- Active Area: 152.4mm (W) x 91.44mm (H)
- Dot Pitch: 0.0635mm(W) x 0.1905mm(H)
- Outer Dimensions: 185.5 × 122 × 32mm L x H x D
- Aspect Ratio: 16:9
- Brightness: 250 CD/M²
- Contrast Ratio: 500:1
- Light Source: LED
- Surface Treatment: Anti-Glare
- Viewing Angle: 70/70 (left/right) and 50/70 (up/down)
- Video input Signal: VGA, RCA, HDMI, DVI (requires adapter)
- Compatibility: PC, MAC
- Input: 1 VGA, 2 RCA Video, 1 RCA Audio input, 1 HDMI or DVI
- Power: AC to DC power adapter (Input: 100-240V, 50/60Hz, 0.60A Output: 12V, 1200mA)
- Power Consumption: <8 Watts
- Touch Screen: Four Wire Resistive Touch
- Touch Interface: USB or RS232
- Speaker: Built in, 1 Watt
- Remote Control: Infrared
- Stand: Detachable, Swivel, Tilt
- Storage Temperature: -20C to 70C
- Operating Temperature: -10C to 60C
