Home > Monitors >
  Lilliput 7" SKD Open Frame Touch Screen VGA Monitor with HDMI, DVI Input
Alternative Views:
Our Price: $198.99
Sale Price: $184.95
You save $14.04!
Stock Status:In Stock
Product Code: MON-121
Description Extended Information
This Lilliput LCD touch screen is similar to the panel found in the Lilliput 669GL-70NP/C/T.  If you need a solution integrated into your own custom enclosure, this may be the monitor for you.  The disassembling work is already done for you.  Simply install this into your custom enclosure or dash panel kit.
  • Full-function infrared remote control
  • Touch control
  • Multi-language on screen display
  • 2 Composite Video Inputs
  • VGA Input
  • HDMI/DVI Input
  • Audio Input
  • Color system: PAL / NTSC, SECAM (optional)
  • Touchscreen driver interface: USB
  • Display Screen: 7 inch TFT LCD
  • Resolution: 800 × 480 (1,152,000) pixels
  • Displays up to 1920 x 1080
  • Color System: PAL-4.43 NTSC-3.58
  • Ratio Aspect: 16:9
  • Contrast Ratio: 500:1
  • Brightness: 300cd/m2
  • Viewing Angle: 50/70(U/D),70/70(L/R)
  • Input Voltage: DC 11-13V
  • Power Consumption: ≤8W
  • Dimension(mm): 165L × 104W × 5.5H
Includes:
  • VGA Cable
  • AV Cable
  • DC 12V Home Power
  • 12V Car Power Adapter
  • Remote Control
  • Touch Pen
Browse for more products in the same category as this item:
Monitors
Monitors and Touchscreens
Monitors and Touchscreens > 7" Touchscreens
Monitors and Touchscreens > Lilliput
