Home > Monitors and Touchscreens > Monitor Accessories > Spare Monitor Parts >
  Lilliput 7" Touchscreen Replacement for the 669GL-70NP/C/T
Our Price: $13.95
Stock Status:In Stock
Product Code: MON-028-001
Description
This is a touch screen are replacement for the Lilliput 669GL-70NP/C/T.
(If you purchased your monitor elsewhere, make sure that this is the correct version of the touchscreen that you need.)
This is only the touchscreen, no controller board or LCD panel are included.
Measurements:  16.4 cm x 10.3cm
Features
    • Touch Screen Panel
    • Size: 7"
    • Resistive 4-wire panel
    • Direct Replacement Lilliput panel
Browse for more products in the same category as this item:
512MB DDR2 SODIMM PC2-667 RAM $19.99
4-Port USB Hub USB-MH20-GRY $5.99
4-Pin P4 - Molex Power Cable $3.99
3ft USB extension cable $5.00
Major Brand 2GB DDR2 DIMM 800MHz, PC2-6400 RAM $39.99
Major Brand 250GB 2.5" SATA Hard Drive $120.00
30 Minutes of Consultation ($330 per hour, purchased in 30 minute increments) $165.00
