Home > Monitors and Touchscreens >
  Lilliput 7" VGA Touchscreen 619GL-70NP
  Lilliput 7
Our Price: $224.99
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: MON-001
Accessories:
Description Extended Information
This touchscreen LCD is for home or in car use and comes with an AC-DC wall plug.
This monitor has historically been the most popular screen for the automotive computing environment. What makes it so special is that it’s VGA so therefore it’s high resolution. Text is readable, great for GPS applications. Another feature that sets this screen apart is its touch screen which makes it easy to control your computer. Applications include: computer display, DVD, VCD, security system, navigation systems and also rear view cameras.
Included Accessories:
  • VGA / USB 2-in-1cable (VGA for PC signal and USB for touch screen monitor control)
  • Universal monitor stand
  • A/V cable (RCA)
  • Remote control with battery
  • AC adapter
  • Car 12V adapter
  • User's Manual
  • Installation CD (driver and software for touch screen)
Features
  • LCD screen size: 7"diagonal
  • Viewable Area: 155mm X 93mm (cut out dimensions for the actual display portion of the screen)
  • Ratio: 16:9 wide TFT LCD screen, high resolution: resolution: 2,400 x 480 = 1,152,000 pixels
  • Support computer display resolution up to 1024 x 768
  • Multi Video system: PAL/NTSC
  • 1x VGA, 2x composite Video inputs and 1x Audio input
  • Touchscreen display (USB interface)
  • Credit card size IR remote control
  • Full function OSD control (Multi-language)
  • Audio output: Speaker built-in & earphone jack
  • Video input signal: 1.0Vp-p, composite video
  • Compact slim panel: 18.7 x 12.5 x 3.3 cm
  • Power input: DC 12V, Power consumption: 9W
Average Customer Review: Based on 1 Reviews. Write a review.
Related Products...
Mp3 Car Screen Cleaning Cloths
Our Price: $3.00
Add
Xenarc 705TSV 7" TFT LCD Touchscreen Monitor
Our Price: $269.99
Add
Xenarc 705TSV 7
7" Touchscreen Replacement for 619 & 629 Lilliput
Our Price: $50.00
Add
7
Lilliput 16.4 Foot 10-pin din cables for Lilliput
Our Price: $40.00
Add
Lilliput 8" Widescreen VGA Touchscreen 889GL-80NP
Our Price: $239.99
Add
Lilliput 8
  8 of 8 people found the following review helpful:
Very Modable January 16, 2007
Reviewer: Brett Martin from Binghamton, NY United States
This is the best deal you can get on a touch screen VGA lcd practically anywhere. Its a great lcd that can easially be modified and installed almost anywhere. Unfortunitally a design flaw means that the alternate video inputs(NOT VGA) stick out to one side. Because I mounted mine inside my dash this meant desoldering the video connector and extending it to make the inputs usiable. Also the buttons on the front are pretty much useless if you use the Ir remote. Luckly the entire LCD is easy to take apart and chop up into exactly what you need it to be if you want a custom install.
Was this review helpful to you?
Browse for more products in the same category as this item:
Monitors and Touchscreens > 7" Touchscreens
Monitors and Touchscreens > Lilliput
CarNetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator $99.95
