Home > Monitors and Touchscreens >
  Lilliput 869GL-80NP/C/T 8" Touch Screen LCD Monitor DVI HDMI
Our Price: $249.95
Sale Price: $214.95
You save $35.00!
Stock Status:In Stock
Product Code: MON-110
Description Extended Information
Introducing Lilliput's first 8" touch screen monitor with HDMI, DVI, and VGA inputs.  HDMI makes it possible to run a long cable to your monitor without encountering the possible flickering associated with analog connections.  Good contrast and rich, deep colors are possible with this digital connection.  High quality Lilliput design and build characteristics.
Features
  • 4 wire resistive touch panel
  • HDMI/DVI input
  • Touch screen control
  • With VGA input, connecting directly to PC, as a Personal Computer
  • With AV input, connecting directly to DVD player, as a car entertainment system
  • With touch screen operation, can as a display terminal unit of industrial equipment
Specifications
  • Panel Size: 8" TFT LCD
  • Backup Camera Wiring is Exposed
  • Resolution: 800 x 480, up to 1,920 x 1,080 pixels
  • Touch Panel: 4-wire resistive
  • Brightness: 250cd/O
  • Contrast: 300:1
  • Viewing Angle: 130/120(H/V)
  • Input Voltage: DC 12V
  • Input Signal: PC(VGA), AV1, AV2, HDMI, DVI
  • Power Consumption: 8W
  • Audio Output: 1W
  • Size(LWD): 211 x 136 x 31mm
  • Weight: 560g
  • Viewable area is 176.64(W)X99.36(H) mm.
Packing Details
  • VGA 9-Pin Cable: 1 Piece
  • 14-Pin SKS: 1 Piece
  • HDMI Signal Cable: 1 Piece
  • DVI Line 24+5/DVI-D Cable: 1 Piece
  • Standalone Bracket: 1 Piece
  • Touch Pen: 1 Piece (on the back of device)
  • Drive Disk: 1 Piece
  • Remote Control: 1 Piece
  • DC 12V Home Power: 1 Piece
  • 12V Car Power Adapter: 1 Piece
  • Operation Manual: 1 Piece
Browse for more products in the same category as this item:
Monitors and Touchscreens > 8" Touchscreens
Monitors and Touchscreens > Lilliput
Lilliput 619GL-70NP-70NP/C/T 7" VGA Touch Screen Monitor $189.95
Lilliput 669GL-70NP/C/T-HB-RV 7" HDMI, DVI, VGA High Brightness, 4 Wire Resistive Touch Screen Monitor $224.95
Lilliput 659GL-70NP/C/T SAW (Surface Acoustic Wave) HDMI DVI Touch Screen Monitor $299.95
Lilliput 629GL-70NP/C/T-DVI 7" VGA Touchscreen with DVI input $209.95
Lilliput 629GL-70NP/C/T 7" VGA Touchscreen w/ Auto Back-up Camera Switch $199.95
Lilliput FA1042-NP/C/T Touchscreen 10.4 inch 4:3 Desktop/Wallmount LCD VGA Monitor $245.95
