Function:
4-wire resistive Touch screen VGA input: 15 pin D-SUB analog RGB interface Automatic display adjustment High-Brightness CCFL Backlight 4 adjustable backlight levels for daytime or night-time use 2 RCA video inputs, Audio Input VGA output device: 800 x 600 up to 1024 x 768 OS for Touch screen: DOS, Win9X/XP, iMAC, Linux systems Composite video output device
Specifications:
PAL/NTSC color system Video input signal: 1.0Vp-p, composite video Speaker built-in Full-function IR remote control Multilingual OSD menu control Last power setting memory for choice available Resolution: 800(H) x (RGB) x 600(V) = 1,440,000 (dots) LCD brightness: 350cd/m2 Contrast Ratio: 500:1 Viewing angle (U/D, L/R): 50/70, 70/70 degrees Power input: DC 12V or AC 100~240V Power consumption: ≤13W Unit dimension(mm): 202L×154W×31H Weight (kg): 702g
