Home > Power > Intelligent Automotive ATX Power Supplies >
  M2-ATX 160W Intelligent DC-DC PSU
Our Price: $69.99
Stock Status: In Stock
Availability: Ships in 1 to 2 Business Days
Product Code: PWR-015
Accessories:
Description Technical Specs Extended Information
160W Intelligent Automotive DC-DC ATX PC Power Supply
M2-ATX is an intelligent, high power, vehicle (car / boat / electric cart) 12V DC-DC ATX PC power supply designed for car pc and battery powered applications. Designed to provide power and to control the ON/OFF switch of a motherboard (car PC) based on ignition status, M2-ATX is a wide input (6 to 24V) vehicle battery operated ATX power supply capable of surviving tough vehicle engine cranks (down to 6V) as well as transient over-voltage situations. Just connect it to vehicle's battery and power up your PC!
Vehicle batteries can provide a limited amount of electricity to your devices. Even if your computer is completely OFF, a PC will still consume a few hundered milliwatts, needed to monitor PC ON/OFF status. When the computer (car pc) is in the suspend/sleep mode, it will consume even more power, because the RAM needs to be powered at all times. The power consumption in the suspend mode is few watts. No matter how big your car battery is, a PC will eventually drain your vehicle's battery in a matter of days.
While in deep sleep mode, M2-ATX constantly monitors your car battery voltage levels, preventing deep discharge situations by automatically shutting down (using a built-in shutdown controller) until battery levels reach safe levels again. No more dead car batteries, no more computer resets during engine cranks, along with multiple timing schemes, small formfactor and very competitive price makes the M2-ATX the premier solution for dc-dc ATX vehicle / car PC power supply solutions.
Onboard Startup/Shutdown Controller
M2-ATX has 8 user selectable microcontroller driven timing modes, allowing you to choose up to 8 ignition/shutdown car pc timing schemes via a built-in shutdown controller. By removing all user-selectable jumpers, M2-ATX becomes a traditional PC PSU with no ignition control (shudown controller bypassed) and it can be used in non-vehicle computer applications.
Dimensions and Compatability
The M2-ATX measures 1.77"(W)x6.31"(L) and is less than 1" high which makes it compatible with the Ampie enclosure and with most Casetronics and Morex enclosures and it is footprint compatible with the M1-ATX. The same version of microcode will run on both M1-ATX and M2-ATX.
Note: M2-ATX provides up to 8A on the 12V rail, making it ideal for operating most low power P4, P4-M, Celeron, ADM systems. Low power Geode and VIA processors (C3, C7) will work as well, leaving ample power for 12V or 5V peripherials (multiple 3.5" hard drives, CDROM, etc).
Shipping
The M2-ATX Bundle comes with:
-160W M2-ATX PSU
- 20 pin ATX cable extender plus HDD and Floppy power (9inch)
- Power input cable harness terminated in 0.25' fastons (12inch)
- 2 pin M/B on/off power ON control wire harness (9inch)
- 3 jumpers to control various power sequencing schemes
Features
  • NEW 160 watts output
  • Ideal car Power supply for operating low power P4, P4-M, Celeron, AMD systems
  • ATX, 6-24V wide input range (not for boats) see m2-atxHV and technical reasons.
  • Intelligent shutdown controller
  • ON/OFF motherboard control
  • Survives vehicle engine cranks
  • Battery deep discharge prevention
  • High efficiency, 160 watts output
  • "Anti-Thump" Amplifier remote control
  • 15A automotive fuse (mini-blade)
  • VIA, P4 and AMD CPU support
Average Customer Review: Based on 4 Reviews. Write a review.
Related Products...
Mp3Car DSATX
Our Price: $159.99
Add
Mp3Car DSATX 220 Watt Automotive Power Supply
M1-ATX 90 Watt - Smart Automotive Power Supply
Our Price: $54.95
Add
GP83 160W Intelligent DC-DC PSU
Our Price: $69.99
Add
Brainstem TTL to RS232
Our Price: $16.99
Add
Serial port for DSATX (Brainstem TTL to RS232 module)
M4-ATX 250W Intelligent DC-DC PSU
Our Price: $89.99
Add
  0 of 1 people found the following review helpful:
Thin PCB November 24, 2008
Reviewer: Michael Drew from Ann Arbor, MI United States
The PCB is not standard 0.062 thickness. This combined with only two mounting holes makes for a board that flexes more than I would like to see a board with surface mount components flex. Certainly costs enough to be 0.062 thick.
Was this review helpful to you?
  0 of 0 people found the following review helpful:
Flawless! June 28, 2008
Reviewer: ERIC TOWNSEND from WARNER ROBINS, GA United States
Running the computer in the truck for over a year now - starts everytime.
Don't overload it and you won't have any problems.
It works, Kinda July 22, 2007
Reviewer: Anonymous person from MI, United States
I have spent months toying with the wiring in my car, trying to figure out why this power supply causes so much darn electrical noise. There are no amperage supply problems. No grounding problems, I have tried everything in the book to make this work and then some. I had an electrical engineer go over my wiring also. Changing grounds, capacitors, regulators, filters, etc. But even he said it's just that power supply producing so much electrical noise. I have a celeron 3.06ghz, 1gb of ddr-3200 ram, hitachi travelstar 40gb hd, and ecs p4m800pro-m mobo. It may be my computer setup relative to this power supply, but this psu has made me one unhappy camper.
  4 of 4 people found the following review helpful:
Perfect for small cases January 16, 2007
Reviewer: Brett Martin from Binghamton, NY United States
I got this powersupply with my Ampie case. It's practically made to fit in the case and all of the wires etc line up great. I went with this model which has the larger 160w over the 90w because its better to be on the safe side with all the USB devices etc I have connected to my pc. The psu has never let me down and the startup/shutdown controler works flawlessly. Setup is simple, move one jumper and it works like a normal PSU so you can install windows etc at home then move the jumper back and connect a wire to your ACC line and power and it takes care of the rest. Go into the power options in windows and "When I press the power button on my computer" and change it to "hibernate" now your pc will automatically hibernate by its self making a super fast boot up time!
Browse for more products in the same category as this item:
Power
CarNetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator $99.95
