Home > Our Products > Computer Hardware > Computer Cases >
  M350 Universal Mini-ITX enclosure by Mini-Box Black
Our Price: $39.95
Stock Status:In Stock
Product Code: ENC-031
Description Extended Information
The Swiss Army Knife of Embedded mini-ITX Computing
Zero noise, small footprint and low power
The M350 is Industry's smallest universal enclosure (192 x 210 x 62mm , 2.5L) capable of housing mini-ITX boards ranging from tiny Atoms to fully featured desktop or mobile CPUs. The M30 permits fanless operation (natural air convection via hundreds of tiny holes) for TDP < 10 watts and CPU-only fan for TDP <= 65watts.
Equipped with hidden (but not shielded) USB docking station for WIFI / 3G / Bluetooth or simply USB flash booting, the M350 is the only enclosure that provides such innovative USB, radio friendly, expansion methods. For internal miniPCI cards or modules, and high gain SMA antenna option is provided on the back of the case.
Multiple bracket options:
M350 mini-ITX enclosure - multiple bracket options - click to open
Multiple Mounting Options:
The M350 enclosure features multiple mounting options, making it ideal for industrial applications.
Mounting options include:
- Vesa mounting (attach in the back of a monitor)
- DIN-RAIL mounting (vertical and horizontal)
- Wall mount brackets
- Rubber feet
Pushing mini-ITX to a new level of miniaturization:
- An optional I/O bracket + PCi riser permits mounting of standard PCI card on top of the Intel D945GSEJT motherboard allowing customers to pack more I/O in a very small footprint (2.5L), a feature not available in any other mini-ITX enclosure.
Smart Power Button:
The M350 power button can be disabled by means of removing a jumper, thus preventing accidental ON/OFF actions. An additional jumper activates an "always ON after power loss' automatic pulse generator that will startup your motherbaord every time power is applied, regardless of BIOS setting!
NOTE: Additional fans can be installed on the hard drive mounting brackets or in the front of the enclosure.
Browse for more products in the same category as this item:
Our Products
