Mobile Systems Integration Specialists
http://www.mp3car.com
View Cart
I
My Account
I
Login
Home
About Us
Help
Contact Us
Our Products
New Products
Open Source Hardware
Vehicle Specific Parts
Mp3Car Forum Made Products
Embedded & Industrial Computers
Custom Car Computer Systems
Monitors and Touchscreens
Computer Hardware
iPad Vehicle Mounts
CarNetix Products (CNX)
Navigation and Software
Engine Diagnostics and OBD
Audio, Radio, and Video
Peripheral Devices
Power
Fusion Brain & Accessories
Mp3Car Swag
Mp3Car Bargain Basement
Information
Mimics
Mp3Car Store Policies & FAQ
Review Your Experience Here
Premium Services & Support
Contact/About Us
Car Computing FAQ
Mp3Car Forums
Mp3Car Homepage
Home
Power
Intelligent Automotive ATX Power Supplies
M4-ATX 250W Intelligent DC-DC PSU
Alternative Views:
Our Price:
$88.00
Sale Price: $77.95
You save $10.05!
Stock Status:In Stock
Product Code:
PWR-031
Description
Technical Specs
Extended Information
Intelligent Automotive / Car DC-DC ATX PC Power Supply
See an mp3Car review of this product
HERE
M4-ATX is an intelligent, high power, vehicle (car / boat / electric cart) DC-DC ATX PC power supply designed for use with car pc or general purpose battery powered applications. Designed to provide power and to control the motherboards's ON/OFF switch based on ignition status, M4-ATX is a wide input (6 to 30V) vehicle / car / battery operated ATX power supply capable of surviving tough car engine cranks (down to 6V) as well as transient over-voltage situations. Connect it to your car / boat / RV / solar battery and power up your PC!
By using Patent Pending HyperWatt[TM] technologies, M4-ATX packs an impressive amount of power relative with its small footprint. M4-ATX has several key advantages over traditional power supplies:
Programmable shutdown / sleep modes via optional serial cable.
Fits any motherboard equipped with a 20 or 24pin ATX connector.
100% silent, fanless, no moving parts.
Operates from 6-30V, multi-chemistry batteries supported.
Highly efficient design, does not produce a lot of heat.
Works with any Intel Core Duo as well as all VIA or AMD processors.
Firmware on the M4-ATX can be changed to accommodate different behaviours. OEM / reseller integration is welcome. Please send en email to
m1-atx@mini-box.com
with your custom requirements.
Minimum Input Operating. voltage:
6V
Maximum input Operating voltage:
30V (hard clamping will occur at 34 V)
Deep-Discharge shutdown threshold:
11.2V
Input current limit (fuse protected):
mini-blade 25A
Max Output Power:
250 Watts / 300 Watts peak
Deep Sleep Current Consumption
< 1.6mA
Operating temperature:
-40 to +65 degrees Celsius (-40F to 149F)
Storage temperature:
-40 to +125 degrees Celsius (-40F to 257F)
MTBF:
200,000 Hrs
Efficiency:
>95%, all rails combined, 50% load
PCB size:
120mmx93.95mm (4.9"x3.7")
Input Connectors:
M4 screw terminal
Output Connector ATX Power:
ATX Power 24 pin (Molex P/N 39-01-2200)
Maximum Power Characteristics
Output Rail
Current(Max)
Current Peak (<60sec)
Regulation
5V
15A
20A
1.5%
3.3V
15A
20A
1.5%
5VSB
1.5A
2A
1.5%
-12V
0.15A
0.2A
10%
12V
10A (see below)
16A (see below)
2%
When operating at < 8V or >28V or extreme temperatures, de-rate by 25%, ventilation might be required.
When operating at constant 160 watts or more, forced ventilation might be required.
12V Rail Output Current (12v buck/boost converter)
Input
12V out current
Input (V)
12V out current
6-8V
8A (10A peek)
11-16A
12A (16A peek)
6-11V
10A (12A peek)
16-30A
12A (14A peek)
Additional product information:
M4-ATX Manual
M4-ATX Dimensions
Please note:
Mp3Car will not provide tech support in regards to use and set-up of this product. Customers are expected to use the
Mp3Car forums
for assistance in these areas. A good place to start is the
Mp3Car Power Supply sub-forum
. Registration on the forums is easy and free.
Features
NEW!
Plug-In Smart car PC PSU
250 Watts (300 Watts peak)
20/24 pin ATX, 6-30V wide input
Programmable timing settings via USB
Intelligent shutdown controller
ON/OFF motherboard control
Survives vehicle engine cranks
Battery deep discharge prevention
High efficiency, 250 watts output
"Anti-Thump" Amplifier remote control
<1.5mA standby current
VIA, Intel Core Duo, AMD CPU support
manufactured by
mini-box.com
ROHS compliant version
USB 2.0 interface
Accessories for this product...
Mini-Box SFX / ATX enclosure for M4-ATX
Our Price:
$3.95
Add
Related Products...
M4-ATX-HV 250W Intelligent DC DC PSU Power Supply
Our Price:
$88.00
Add
DCDC USB POWER BOX, For Use with Mini-Box DC-DC co
Our Price:
$4.95
Add
M2-ATX 160W Intelligent DC-DC PSU
Sale Price: $64.99
Add
DCDC-USB Intelligent DC-DC Converter with USB Inte
Our Price:
$69.95
Add
Mp3Car DSATX
Our Price:
$159.99
Add
Browse for more products in the same category as this item:
Power
Power
M3-ATX 125 Watt - Smart Automotive Power Supply
$64.99
M2-ATX-HV 140W Intelligent DC-DC PSU
$64.99
Lilliput 889GL-80NP/C/T 8" Widescreen (16:9) VGA Touch Screen
$204.95
Lilliput 809GL-80NP/C/T 8" (4:3) VGA Touch Screen TFT LCD Display
$189.95
Lilliput 8 Inch USB Touch Screen UM-80/C/T
$184.95
