M4-ATX
is an intelligent, high power, vehicle (car / boat / electric cart)
DC-DC ATX PC power supply designed for use with car pc or general
purpose battery powered applications. Designed to provide power and to
control the motherboards's ON/OFF switch based on ignition status,
M4-ATX-HV is a wide input (6 to 34V) vehicle / car / battery operated
ATX power supply capable of surviving tough car engine cranks (down to
6V) as well as transient over-voltage situations.
Connect it to your car / boat / RV / solar battery and power up your PC!
By using Patent Pending HyperWatt[TM] technologies, M4-AT-HV packs an
impressive amount of power relative with its small footprint. M4-ATX-HV
has several key advantages over traditional power supplies:
- Programmable shutdown / sleep modes via optional serial cable.
- Fits any motherboard equipped with a 20 or 24pin ATX connector.
- 100% silent, fanless, no moving parts. - Operates from 6-34V, multi-chemistry batteries supported.
- Highly efficient design, does not produce a lot of heat.
- Works with any Intel Core Duo as well as all VIA or AMD processors.
Firmware on the M4-ATX-HV can be changed to accommodate different behaviours. OEM / reseller integration is welcome.
M4-ATX-HV Characteristics
| Minimum Input
Operating. voltage |
6V |
| Maximum input Operating voltage |
34V (clamping occurs at 36-38V range) |
| Deep-Discharge shutdown threshold |
11.2V |
| Input current limit (fuse protected) |
Mini-blade 25A |
| Max Output Power |
220 Watts / 275 watts peak |
| Deep Sleep Current Consumption. |
< 1.6mA |
| Storage and operating temperature |
-40 to +125 degrees Celsius (storage), -40 –
65C (operating) |
| MTBF |
MTBF 200,000 Hrs |
| Efficiency (Input 10-16V) |
>94%, all rails combined, 50% load. |
| Input connectors |
M4 screw terminal |
| Output Connector |
ATX Power 24 pin (Molex P/N
39-01-2200) |
*Unit shuts down when internal temperature sensor indicates > 85C. This value can be changed with software.
Maximum Power Characteristics
| Output Rail |
Current (Max) |
Current Peak (<30 seconds) |
Regulation |
| 5V |
12A |
15A |
1.50% |
| 3.3V |
12A |
15A |
1.50% |
| 5VSB |
1.5A |
2A |
1.50% |
| -12V |
0.15A |
0.2A |
10% |
| 12V |
10A (see below) |
12A (see below) |
2% |
When operating at <8V or >28V or extreme temperatures, de-rate by 30-50%, ventilation might be required. When operating at constant 160watts or more forced ventilation is required.
12V Rail Output Current (12V buck/boost converter)
| Input (V) |
12V out current |
Input (V) |
12V out current |
| 6-8V |
8A |
11-16V |
10A (12A peak) |
| 8-11V |
10A (12A peak) |
16-34V |
8A (10A peak) |
Support and warranty: Standard Hardware Warranty 1Year / US, 2 Year EU.
