Home > Our Products > Computer Hardware >
  MacPac Power Cable Kit For the Mac Mini For Mac Mini Models up to June 2010 (Excludes Unibody Mac Mini)
Our Price: $24.95
Stock Status:In Stock
Product Code: CBL-086
Add A Button:
   Install a manual power switch in a location of your choice.
Description Extended Information
A "plug and play" power cable kit for your Mac mini! No more cable splicing!!
Carnetix is pleased to announce the only "plug-and-play" power cable solution for the Apple Mac mini and your CarComputer application! The "MacPac" power cable kit connects your mini to the CNX-CA-P1900 or CNX-P2140 DC-DC regulator to provide a quick and simple automotive installation. You are no longer required to cut and splice your Apple AC adapter (brick). The MacPac provides a pre-wired cable between the regulator (P1900 or P2140) and the Mac mini, and includes all power and control signals necessary for full automatic startup and shutdown of the mini. The MacPac is fully compatible with the original Mac mini as well as the new Intel-based mini.
The main white power cable is ~3' from the mac mini power connector. This means your mac mini can be about ~3' from your Carnetix device. Custom cable extensions should be possible to create but will void your warranty.
NOTE: This Cable package is designed to work with Mac Minis manufactured before June 2010 (excludes Unibody Mac Minis).
Features
The MacPac kit includes a Y-cable adapter that is installed between the mini's power button and the motherboard. This allows you continue to use the original Mac mini power button as well as the P1900. The MacPac and Y-cable allow you to easily remove the Mac mini from the car so that you can take the mini inside for software tweaking or updates. When indoors simply use the AC adapter that came with your mini.
The MacPac also provides access to the P1900 or P2140 secondary output, DelayOn amp control, and ground via seperate wires.
http://carnetix.com/installation/IWill_power_cable_instructions.pdf
Please see the IMPORTANT installation instructions in the "Extended Information" tab.
Browse for more products in the same category as this item:
Our Products > Computer Hardware > Cables and Adapters > Cable Kits
Our Products > Computer Hardware > Cables and Adapters > Power Cables
Our Products > CarNetix Products (CNX)
Our Products
